![]() | Home > Technical (L322) > Adaptive dynamic fault/wiped ecu L322 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
Never heard of that before. I’m assuming it’s still possible to read the error codes?
Bennyis01 Member Since: 02 Mar 2018 Location: Birmingham Posts: 15 ![]() ![]() ![]() |
Yes error codes are readable but only saying lost communication with the body control module code U0140
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
Had a similar problem, ended up replacing the module in the rear of the car. All good after that. Not saying it is the answer for your wheels, just my experience. |
Thanks for getting back ,it's looks as though it's heading that way , how much was a replacement if u don't mind me asking
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2748 ![]() ![]() |
Which module has lost communication with the body control module? |
Not sure if it is height or suspension |
Suspension is height but there are several modules dependent on each other. Can you post the full picture of the DTC display? It should identify the particular module. |
Those are only pics I have of fault codes the 1 states its body control module other than that I will try find more out later. |
I bought of eBay, paid £40 for it |
Thanks for that mechanic has just ordered me 1 cost a little more but if it works I'll be happy
Guys would just like to post that today was a happy ending finally for all the faults around adaptive dynamic fault
