Home > Maintenance & Mods (L322) > Cleaning Interior Plastics
supershuttle
Am I safe to assume that the plastic trims, doors, dash etc are completely through coloured - not painted and I can give them some very aggressive cleaning.
The reason is the doors in particular are sticky in places, like the've got some sort of coating on, this in itself wouldn't be a problem but it has a slight colour cast - greenish!
So can I attack it without fear with a kitchen style cleaner, maybe even one that is bleach based Confused
Or has anyone of you esteemed forum contributors got any other suggestions.
Thanks
Geoff Geoff
Post #66972 4th Jun 2011 9:10pm
Vogue
door linings are coloured through, seat bases and trim in the boot and on some of the pillars is coated, i'd be very careful with household cleaners - I've fiucked up in the past using them on cars Rolling Eyes
Post #66975 4th Jun 2011 9:16pm
I just used a Magic Sponge to clean the plastic on my doors and dashboard and the results are amazing, no hard scrubbing required and every thing came up like new . 2008 MY Supercharged
Post #66987 4th Jun 2011 10:19pm
ric355
I have just used some of this on the top of my doors where there is ingrained dirt from elbows etc today.
http://www.halfords.com/webapp/wcs/stores/...yId_165651
It is actually a leather cleaner but that makes it safe for use on many other surfaces too. Agitate lightly with a soft brush if the surface you are cleaning has a grain, and of course test a small area first but so far I've never found it react with anything.
Post #67000 4th Jun 2011 11:21pm
Geoff- let rip with some bathroom cleaner. I did mine with some grim and lime remover over 12 months ago and there fine! Came up a treat but need cleaning again now. Just make sure you use loads of water to clean it off as long term might cause some issues.
Post #67002 4th Jun 2011 11:43pm
claud
United Kingdom 2018 Range Rover Autobiography TDV6 Corris Grey
For the gentle approach, try Autoglym Upholstery Cleaner! 2018 Range Rover Autobiography
2010 Land Rover Freelander XS
1959 Series II
1950, 1952, 1954. 1955, 1957 Series I
1952 Minerva Ambulance
Post #67102 5th Jun 2011 7:19pm
claud
1959 Series II
Post #67103 5th Jun 2011 7:20pm
On plastics you'd be amazed what a normal nail brush and warm water with fair liquid can do. Discovery 4 HSE
1993 90 Tdi
Post #67140 5th Jun 2011 9:27pm
supershuttle
Gave it a good scrub - passenger door came up a treat - like new. Drivers door is a whole different kettle of fish, it's been painted! I think maybe that the leather armrest/doorhandle was worn so that got a recolour, fine, but they have kept going and sprayed some of the door panel to maybe blend it in there is even overspray if you look closely. What where the Censored cretins thinking, so next job is to get the paint off and get it back to original- am I OK to wipe with thinners or will the plastic "melt" - advice?
Geoff Geoff
Post #67340 6th Jun 2011 9:17pm
Vogue
i'd avoid cellulose thinners, it dissolves certain plastics - to my cost - white spirits is ok on plastic, but not sure if it will remove dry paint.
Post #67347 6th Jun 2011 9:41pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
If it's on the plastics - and it's coloured right through, try duraglit (brasso). Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #67348 6th Jun 2011 9:45pm
gingerbiker
2006 Range Rover HSE Td6 Stornoway Grey
+1 for autoglym leather cleaner for interior plastics, but baby wipes clean most day to day car grime up of the interior really well
wipes are also excellent on laptops/ mobiles etc etc...anything that you can not get 'wet' when cleaning
carl
Post #67353 6th Jun 2011 10:33pm
supershuttle
Saw and bought a new complete door trim on fleabay for £100 - seemed like the shortest distance between two points - but thanks for all the advice Thumbs Up Geoff
Post #67600 8th Jun 2011 12:29am
I'll echo an earlier sentiment.....
For cleaning (not stain removal) the best chemical is water! Add detergent (Fairy Liquid) to help the water remove dirt and soil. Oh, and don't be fooled by "more bubbles is better" - a proper solution of detergent in water has hardly any bubbles - too high a concentration and you just end up smearing and leaving detergent on the surface you are cleaning.
Use a damp cloth for most cleaning, for heavy soil always soak first.
Also suggest use microfibre cloths as they help to get into the tiny gaps we can't see.
Baby wipes are also good - especially the hypo allergenic ones (don't want your FFRR getting eczema now do we?)
Remember to rinse with clean warm water afterwards.
Glass is a different matter. Use as above to clean, then use proprietary window cleaner to get a clear view.
If you must use a chemical in a spray gun for any cleaning, spray the cloth not the surface before applying and "cleaning"
This advice doesn't just apply to cars, same goes for anything. .
Post #68146 10th Jun 2011 10:35pm
supershuttle
Too good to be true, couldn't tell from the picture when it arrived the trim was stunning but finished entirely in leather so it didn't match the others - sent it back Crying or Very sad Geoff
Post #68154 10th Jun 2011 11:26pm
