![]() | Home > In Car Electronics (L405) > Sat Nav Volume |
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 492 ![]() ![]() ![]() |
I've got exactly the same issue. I haven't found how to mute it in desperation either! 2017 Range Rover Vogue V6 Diesel
AnnualMan Member Since: 16 Apr 2023 Location: Zurich Posts: 188 ![]() ![]() |
For the facelift version I have, muting is done by clicking on the six boxes that overlay on the map, then choosing the 'mute' tile that appears on the next screen 2025 P550e AB |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 302 ![]() ![]() ![]() |
I haven't tried this in the L405 but in my old D4 I had a similar problem. I found that by leaving the radio 'on' but set at zero volume it would keep the 'adjusted' sat nav volume low. However, if I tuned all audio off, the sat nav would reset to loud with every instruction.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
go to setup,
? No volume presets that I can find 2025 P550e AB |
main home screen vehicle setup? ... - .- -.
PhillV8s Member Since: 03 Jun 2022 Location: Worcestershire Posts: 45 ![]() ![]() ![]() |
Press setup (button on side of screen)
I have the facelift L405 so no button on the side of the screen 2025 P550e AB |
The > 2017 instructions simply say
Exactly what I do, yet the next spoken instruction is back to the original volume level.
you need to find where the volume pre-sets are hidden.. ... - .- -.
M11buc Member Since: 06 May 2019 Location: Newcastle upon Tyne Posts: 44 ![]() ![]() ![]() |
Hi annual man, for what it’s worth. Mine is similar age.
Same for me. When the sat nav speaks i turn it down and then the next instruction is back up to the same level. 2017 Range Rover Vogue V6 Diesel 2006 Range Rover Vogue V8 Diesel - gone |
Was pretty annoying on my long trips last week 2025 P550e AB |
