Home > Technical (L405) > rear end sliding
rear end sliding
i've searched the forum and cant find anything similar to my problem..
when turning right and also going round a roundabout at normal speeds and in the dry ,my rear end seems to 'slide' out..
if i accelerate, this is made worse like a rear wheel vehicle sliding on wet roads..
its not so noticeable when turn left.
tyres [20''] and pressures are ok, a set of 21'' wheels/tyres did the same and i'm back on 20''..
transfer box and rear diff oils were changed 12k miles ago by a main dealer..
my FF has been up on a ramp and been checked with a pry bar for any wear on bushes etc..
any ideas? ... - .- -.
Post #670092 30th Jul 2023 12:52pm
nickt68
2015 Range Rover Vogue SE SDV8 Santorini Black
When I had my transfer box serviced for similar reason Stan, they warned me that they often need the oil changing again to fully cure the problem. Mine has started to feel odd at the back left again and is going to have the (transfer box) oil changed again when it's in for service in a couple of weeks.
Post #670098 30th Jul 2023 2:36pm
did the first oil change solve your problem Nick? ... - .- -.
Post #670101 30th Jul 2023 3:30pm
nickt68
Yes, big improvement straight away Stan but it has gradually come back, albeit not as bad, over the last few thousand miles. I'm hopeful that the next change should fix it for good! It's just an oil change this time and not the software update too
Post #670102 30th Jul 2023 3:39pm
My L322 did that Stan and it turned out to be a rear hub bush. According to my Indy, it’s hard to find with a pry bar because they check it with all the weight of the car loaded on it, making it seem ok. Got - 2017 SDV8 Autobiography in Loire Blue
Post #670109 30th Jul 2023 4:37pm
Could it be this Stan...
Double flush and software update sorts it apparently...
https://www.fullfatrr.com/forum/topic50586.html Pete
Post #670115 30th Jul 2023 5:08pm
thats interesting Pete and although it refers to a judder rather than the sliding rear , it could solve my problem.
i am also kinda drawn to Nicks solution with the transfer box needing an oil change but this was done on mine 12k miles ago [or was it?]
dont think its a bush Alan as my son had pry barred it on a four arm lift [not a ramp, sorry Embarassed ]
i did try a calibration on the transfer box with the iidtool but got an error 'E7' code, maybe it needs a software update?.... ... - .- -.
Post #670117 30th Jul 2023 5:49pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Hi Stan
Has your car got a closed rear diff?
If so you may be experiencing the same problem I have after paying for a double flush which did not fix the problem, it went back to JLR again and it is booked in for a replacement rear diff (Under warranty) It's only taken about a year to convince them it was the problem. the car has only covered 20k miles. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #670120 30th Jul 2023 6:56pm
i dont know Alex...how do i determine this?
so you think that it could be the diff.....sounds plausible as this could explain why the slide results mainly when i turn right... ... - .- -.
Post #670128 30th Jul 2023 9:12pm
Lots of ways to find out but you can do it this way from your seat...!!!
Stick your VIN in here, it should say....
https://www.vindecoderz.com/ Pete
Post #670130 30th Jul 2023 10:01pm
Tinman
The Dealership had to get confirmation from technical at JLR to change the diff which the warranty company then approved,
The part is on backorder, so it is booked for fixing in October. 2017 SDV8 4.4 silicon silver AB
Post #670137 31st Jul 2023 8:42am
didnt realise this info was on the build sheet Pete..
looked and it says ''rear axle open differential ''
@Alex, does this make a difference? ... - .- -.
Post #670141 31st Jul 2023 9:32am
Tinman
When you go to the screen 4x4 information it will show a padlock (or not).
If you have a padlock that is a closed diff which has a clutch plate system which is my problem the clutch plates do not disengage.
If you don't have the padlock, it`s open then it will be a different problem.
I believe Most of the autobiography cars were fitted as standard. 2017 SDV8 4.4 silicon silver AB
Post #670152 31st Jul 2023 12:35pm
Looks like you don't have a locking rear diff. You are back to the double flush and software update on the transfer box... Thumbs Up Pete
Post #670153 31st Jul 2023 1:17pm
Stan, when you checked the car on the ramp, did you only check the car with the suspension on full droop?
Post #670184 1st Aug 2023 12:15am
