![]() | Home > Maintenance & Mods (L322) > Oil Level Overfilled |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
Suck it all out now
Sensor has been known to fail too. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Lordy9099 Member Since: 22 Jul 2023 Location: Manchester Posts: 23 ![]() ![]() ![]() |
Does that include removing the sump for the turbo drain? Also if you remove this plug and drain do you have to prime anything or does it run over from the main sump?
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3326 ![]() ![]() ![]() |
Forget about the turbo drain sump for now - just drain the lot and refill with 8.5-9L to make sure you are not underfilling an engine with a broken level sender. 2012 TDV8 Vogue (L322) |
Don't over think it |
Lordy, if you took your car into JLR tomorrow for any service, they would only suck the oil out the top and refill with 8-9lrts. So, as above. Don't overthink it for now! Simply suck the rest of the oil out and put 8ltrs back in and then recheck your digital level. This will give you proof your level sensor is working or not sir? ![]() |
Hi Guys,
How is it possible to overfill it by that amount? Who serviced it last? 2012 TDV8 Vogue (L322) |
I haven’t a clue, it was some place in Scotland where the previous owner took it, thanks fully it’s only done a few hundred miles so hopefully hasn’t done any damage and I caught it early. Great example as to why I service all my new cars from scratch again |
Bloody hell! You were lucky! 👍 |
Think I would have known of any engine damage already or could it have done damage that hasn’t yet shown? |
Any oil leaks? 2012 TDV8 Vogue (L322) |
Not that I’ve seen |
Name and shame that garage so folks can avoid them. That's insane 😳 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
