![]() | Home > Technical (L405) > Engine stops |
| millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 341
This may explain it: - LTB01083
| GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 243
Thank you very much. That describes perfectly what happens.
Thanks Guys I have found all the information I need to give to my Indy tomorrow. 2013 SDV8 4.4 SE Luxor.
I have read all the LR Technical Bulletin. I see that the replacement loom section may be the better way to go.
I couldn’t locate the part either. So I disassembled the upper (easily assessable) connector and doused it in Servisol Switch and Contact cleaner.
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885
Correct repair is a new electrical connector for the rail pressure sensor, which comes with a length of wiring to remove the connector at the top of the cam cover |
Thanks Mike, that’s exactly what my Indy said. Britpart.have them, unlike LR. So as soon as it comes, it will be fitted. 2013 SDV8 4.4 SE Luxor.
Wire fitted. No further problems. 2013 SDV8 4.4 SE Luxor.
| Bikeracer Member Since: 24 Aug 2023 Location: Newark Posts: 23
Thank you very much for that explanation, my L405 is behaving in exactly that way. I have sent a copy of your information to my Range Rover man and I hope to get everything sorted in the next few days. |
| All times are GMT |
