Home > Technical (L322) > L322 rear subframe replacement
Rang13
United Kingdom 2004 Range Rover SE 4.4 V8 Epsom Green
My 2003 L322 has just failed it's MOT as a result of serious corrosion to the rear subframe and requires welding. I am exploring the possibility of replacing the subframe but I am experiencing some difficulty with the part no. Rimmer Brothers Ltd of Lincoln suggest KHE500050 for my car which is apparently obsolete. However ebay etc suggest KHE500100 as the part no? Any advice/help would be appreciated by club members. BTW the current list price is £1,684.80 OEM.
Post #670221 1st Aug 2023 11:20am
There are several on eBay secondhand for @ £250
https://www.ebay.co.uk/sch/i.html?_from=R4...p;_sacat=0 .
Post #670231 1st Aug 2023 12:08pm
Merchy
Wow that is expensive Shocked Another route you could take is to Have a look on ebay and gentlemen of salvage, there are quite a few for sale that look to be in reasonable condition, you could have it blasted and coated prior to fitting.
Post #670232 1st Aug 2023 12:09pm
If it's failed on the rear subframe how bad are the rear of the sills and the rear arches, take off the sill covers and check, it may be a lost cause if there is rot there as well.... Pete
-Click here for Thread-
Post #670235 1st Aug 2023 1:09pm
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
As per Joe90 eBay has this one that looks pretty good at first sight and a decent price:
https://www.ebay.co.uk/itm/175839795281?ha...R_bmjJK2Yg
Post #670237 1st Aug 2023 1:48pm
cass
+1 for Haylands advice. At 20 years old this could become a serious money pit.
Of course if the rest of the car is very good then it will be worth saving but it's very easy to spend wildly on these things.
Post #670246 1st Aug 2023 4:27pm
DrRob
As above. Check for any other rot in the sills and arches (remove sill covers and rear inner wheel arch liners) then make a decision.
Fit a good secondhand subframe that you've treated and painted etc before fitting. Cover it in Lanoguard or a wax etc. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #670257 1st Aug 2023 7:04pm
bobsin
2004 Range Rover Vogue Td6 Epsom Green
Fixed Rust
Fixed sills, arches and replaced rear sub-frame (and brake lines) on my 2004. Plenty good steel to weld to when frilly bits cut out. hope that's it for now.......
Post #670278 2nd Aug 2023 2:52am
