Home > Technical (L322) > Figure out if its been remapped?
mgrover
Hello,
anyway to do this?
am told by a previous mechanic they remapped it for his mother in law but am not sure exactly what was done, whether they messed with the EGR or anything like that.
claimed 400bhp Laughing
the way the gearbox thuds at 177k that maybe true. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #670785 9th Aug 2023 8:25am
JayGee
Try timing 0-60 on a 'dyno' phone app. Some remaps increase the torque significantly (and the way it loads up) which is the main issue with the drivetrain rather than HP. 2012 TDV8 Vogue (L322)
Post #670788 9th Aug 2023 8:33am
mgrover
ah nutty 800nm of torque or someshit is what they pretty much said.
i guess app is only way to tell Its actually a sport Sad
Post #670790 9th Aug 2023 8:52am
JayGee
Assume it is remapped and get it returned to stock if you are having gearbox issues and want to prolong it's life. 2012 TDV8 Vogue (L322)
Post #670792 9th Aug 2023 9:21am
mgrover
tbh with the gearbox feeling thuddy, in my head am budgetting in a replacement/rebuild already. Its actually a sport Sad
Post #670795 9th Aug 2023 9:28am
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
Re: Figure out if its been remapped?
There are other ways to hasten a MiL's demise.
Post #670796 9th Aug 2023 9:29am
JayGee
Fluid change and software update can help but depends on the severity of the harsh changes. Also if it's a crude remap it won't play well with the gearbox programing. 2012 TDV8 Vogue (L322)
Post #670797 9th Aug 2023 9:33am
mgrover
had a full flush recently thanks to Bodsy.
I haven't touched anything else.
I wonder if its worth resetting the clutch adaptions(not the full adaptations)
but tbh its not end of the world, its just a slight thud when getting into Drive. While driving tis pretty smooth. Its actually a sport Sad
Post #670799 9th Aug 2023 9:55am
Byg Nyge
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
If its just a thud when putting into drive I'd suspect one of the several prop shaft joints, had the same on a Nissan Navara, it was the rear prop shaft U/J, later the same when a front prop shaft U/J spat the dummy out.
Post #670892 10th Aug 2023 2:02pm
DrRob
Press on the brake pedal harder before shifting into D. See if that makes a difference Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #670900 10th Aug 2023 5:08pm
mgrover
huh that seems like a easy enough to do. will give that a shot thanks
i now have a boost solenoid valve stuck(!yay) Its actually a sport Sad
Post #670961 11th Aug 2023 10:05am
