Home > Technical (L322) > autolights question
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
autolights question
Hi all
Need a bit of advice from people with autolights on their range rovers, when you have the light switch in auto mode and it goes dark when the auto lights turn on do get you both dip beam and side lights as well as interior illumination e.g. dash lights up etc..
Thanks
Matt
Post #67100 5th Jun 2011 7:17pm
algt2
Scotland 2006 Range Rover Vogue 4.4 V8 Zermatt Silver
Yes, it does on mine!
Post #67104 5th Jun 2011 7:21pm
Yeah same with me ... Thumbs Up
Post #67107 5th Jun 2011 8:06pm
mattstevenson2005
thats great thanks! im just in the middle of programming a brand new LCM 4 ecu and i have got everything working apart from interior lights with autolights i think the problem lies in the one of the 12 coding data banks
QUESTION:
Does anyone on here own a faultmate extreme and have a range rover with autolights, if so would you be able to read the settings from your LCM unit and store in a html and then email or pm the html file to me, i would be very grateful!
Thanks
Matt
Post #67115 5th Jun 2011 8:16pm
i have a rover all comms, will the readout be the same ..
here it is if it helps matt..
D0:24:A0:00:37:00:00:03:00:08:00:00:00:00:00:4A:64:00:00:00:4E:40:90:02:00:00:40:00:00:00:0A:01:00:8E:E0:FF:
Post #67148 5th Jun 2011 9:57pm
mattstevenson2005
Thanks Scarey, which coding data bank is this from as there are 12 data banks listed on the faultmate, here is the settings page from my faultmate for my LCM4 the coding data banks are at the bottom of the page (this is best viewed in IE)
http://www.myrangerover.co.uk/MyRangeRover/LCM4.htm
Thanks
Matt
Post #67156 5th Jun 2011 10:16pm
daveo
Hi matt, you can borrow my lcm if any good to you. V8 facelift Range Rover Autobiography 22" wheels.
Post #67159 5th Jun 2011 10:20pm
matt, these readings are from my RAC so i cant comment on the faultmate...
Post #67177 6th Jun 2011 8:41am
mattstevenson2005
Thanks Dave! but my faultmate is a single vehicle version so i wont be able to access your LCM because the LCM holds a copy of the VIN number which wont match the one in my faultmate, although i may take you up on the offer of borrowing your PA Soft BMW scanner if blackbox cant sort the issue out.
Matt
Post #67260 6th Jun 2011 5:29pm
