![]() | Home > Maintenance & Mods (L322) > Air Suspension issue. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2765 ![]() ![]() |
You could just replace the bag and possibly the other side too as its condition won't be much better but if the shocks are well-worn then best to replace both assemblies, not just 1 side. The rear bags don't have the same issue as the fronts but if fitting new front asemblies then you'll most likely feel that the rear shocks also need replacing. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3383 ![]() ![]() ![]() |
Are you sure it's the air spring as it could be the air hose, joint or valve block that's leaking. 2012 TDV8 Vogue (L322) |
Seftona3103 Member Since: 13 Aug 2023 Location: Bedford Posts: 4 ![]() ![]() ![]() |
No not really sure where it is leaking. All i know is that you can hear air coming out worse when on off road height.
Thanks for the info. If I need to replace I will replace both fronts first and see how it is. |
Just spoke to one of the guys who said he could feel the air coming out the back so he think its the Air spring.
Sprayed soapy water will show leaks from the airsprinng. |
