![]() | Home > Technical (L405) > L405 Some explanations please |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
Can’t help with your problem but I’d advise against publishing your VIN number in public.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1549 ![]() ![]() |
Each side feeds a different turbo, with the larger one coming in at higher revs. So you will see differing MaF readings.
You've got an outstanding recall for the crank position sensor - get that dealt with first.
yelnats6969 Member Since: 17 Aug 2023 Location: kent Posts: 7 ![]() ![]() |
Fitted new air filters
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
I believe the second turbo kicks in at approx 2500rpm.
That sounds about right, but what/how controls the kick in, I am thinking it might be a sticking solenoid or valve?? when returning from turbo B to turbo A |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1870 ![]() ![]() |
Vacuum activated shut off valve on the back of the turbo
