Home > Maintenance & Mods (L322) > 4.4 TDV8 - Oil cooler or just the gasket?
NDT
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Need a quick bit of advice before I place an order please!
My full fat has oil in the coolant - she had a bit in the tank at the service a year ago and a lot more now.
I’ve seen posts on here suggesting it’s just the gasket, but a new cooler isn’t too expensive from Advanced Factors - any way to check which has gone?
Post #671347 17th Aug 2023 8:16am
JayGee
Replace it as you don't want to do the job twice. 2012 TDV8 Vogue (L322)
Post #671348 17th Aug 2023 8:19am
mgrover
aiye can only agree with above. its 150quid from advancedfactors.
may as well imo. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #671349 17th Aug 2023 8:25am
NDT
Just found this thread: https://www.fullfatrr.com/forum/topic61909...p;start=15
I agree with you both!
Post #671350 17th Aug 2023 8:27am
A much easier home job on the 322 compared with the 405... But if that AF price is correct? Seams a no brainer... Just be careful of the small thin brittle coolant lines! Or better still, factor in replacing them... That's what id do... Thumbs Up Thumbs Up
Post #671377 17th Aug 2023 11:33am
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
After 18 months and 20k miles, I'm still bucking the trend having changed only the gaskets. No issues and everything is still completely dry. Whistle The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #671424 17th Aug 2023 8:27pm
JayGee
I'm >30k miles after just having the gaskets done. 2012 TDV8 Vogue (L322)
Post #671426 17th Aug 2023 8:47pm
mjdronfield
Think my oil cooler had warped when mine was done….. 1 week into ownership in Jan 2016….
So sometimes gasket isn’t enough if it gets left.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #671431 17th Aug 2023 9:24pm
Fox889
I’ll chuck my twopennyworth in……the job is roughly 4-5 hours labour, do the oil cooler & forget it. You may get away with gaskets….but…..if it leaks again, that’s another 4-5 hours labour. Just sayin 😜 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #671443 18th Aug 2023 7:02am
DrRob
Get the one from Advanced. Fit and forget.
Don't forget the discount code for order >£100
AF4LRP
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #671445 18th Aug 2023 7:56am
knwatkins
I just replaced the gaskets on mine. No problem. The cooler was absolutely fine and there was no need to replace it. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #671447 18th Aug 2023 8:35am
cass
I reckon it just depends on who is doing the job, if you're doing yourself (no labour cost) then it might be worth just doing the gasket, if you're paying full price to get it done then it makes sense to replace the cooler,
Post #671454 18th Aug 2023 9:27am
mgrover
id say opposite.
if your giving yourself all that headache, may as well just do it once.
nothing more annoying than doing a job twice haha
i'd also refresh everything i can going in there. Its actually a sport Sad
Post #671457 18th Aug 2023 9:36am
cass
"nothing more annoying than doing a job twice haha"
Except paying for a job twice Laughing
Post #671459 18th Aug 2023 9:55am
mgrover
haha touche sir.
so either way, refresh the cooler
if its leaking also maybe worth fresh coolant to flush the oil and if your expansion tank is dirty that too. Its actually a sport Sad
Post #671462 18th Aug 2023 10:08am
