![]() | Home > Maintenance & Mods (L322) > CVD Rear Shock Replacement |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
No, but the instructions say to renew the paper gasket to prevent moisture ingress into the cabin.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2762 ![]() ![]() |
They are sold as complete units including the mounting bracket. I fitted Bilstein because they were significantly cheaper than genuine LR even though sourced ex UK. |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 438 ![]() ![]() ![]() |
Thanks, guys.
I fitted Bilstein. You still need the paper gaskets from LR…. That didn’t come with mine.
As the gaskets aren't included in the component diagram for the shock I wouldn't expect any genuine or after-market shock to include them. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3380 ![]() ![]() ![]() |
Just because it's leaking doesn't mean it needs replacing. There is a service buletin about leaks and the need to not be concerned. 2012 TDV8 Vogue (L322) |
Thanks, JayGee,
That's called 'jacking' when the rebound damping is more than the compression damping and the strut effectively shortens. Mine have been damp for the last 2 years / 30K miles but still do their job and are now on 160+k miles 2012 TDV8 Vogue (L322) |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 433 ![]() ![]() ![]() |
i used aerosus recently. worked like a champ.
Thanks, everyone.
TorontoDee Member Since: 27 Sep 2022 Location: Toronto Posts: 82 ![]() ![]() ![]() |
I've also got leaks and quite a compression rebound in both my rear shocks.
Bilstein's ordered for my MY2012 S/C. Air springs will be reused. Any pointers, thoughts, please share 2012 Supercharged L322 |
