Home > General > RRS 19'' wheels
Vogue
FFRR and Sporty SE used the same 18" rims for the 2006 MY - these had the greater RRS off set and stuck out more. There is a thread on here about it
Post #67152 5th Jun 2011 10:06pm
Fox wrote:
You mean throw more crap up the sides of the vehicle? Wink
it doesn't richard...i have an extra inch and 4mm and slightly larger tyres and i dont get very dirty 'sides'...
Post #67176 6th Jun 2011 8:37am
Fox
Are you fitting wider tyres like on the RRS or FFRR width tyres?
Post #67184 6th Jun 2011 9:05am
i have 9.5j [extra inch] ,RRS wheels [extra 4mm]...if you get a ruler and measure an inch +4mm out from an existing FFRR 20'' [8.5j] rim you'll see that the RRS will be still under the arch..
Post #67188 6th Jun 2011 9:19am
Fox
And the tyre width?
FFRR is 255 as you know.
4mm extra offset and an inch wider rim should mean they stick out about 17mm more no?
Half the inch plus the 4mm.
FFRR tyres stick out further than the rim anyway, so if you are using FFRR width tyres I doubt there is much difference anyway.
Post #67193 6th Jun 2011 9:54am
here are two pics , the first with 18'' FFrr wheels [8j],
and the second pic with RRS wheels [9.5j]
i cant see how you can claim that 'more' muck will be thrown up on the sides of the range rover...s
Post #67194 6th Jun 2011 10:10am
Fox
It was a quick response, but looking at the facts it's balls. There is very little in it. 17mm is minor.
I still prefer the look of FFRR rims though. Wink
Post #67195 6th Jun 2011 10:12am
i understand and appreciate what you are saying richard Wink , but if you look at the standard FFRR wheels they look to 'tucked' in at the back so the little extra width of the RRS wheels helps to fill in the arches...
Post #67197 6th Jun 2011 10:21am
Just get 22"s Stan you know you want to …. Laughing Laughing Laughing
Post #67209 6th Jun 2011 11:36am
Laughing ...tbh i personally don't like them although some do look good..
Post #67211 6th Jun 2011 11:54am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I prefer the "filled arch" look Cool
Post #67215 6th Jun 2011 12:02pm
Vogue
Fox wrote:
And the tyre width?
Thumbs Up it isn't an extra 1 inch plus the 4mm sticking out, its 12.5 mm and a proportion of the 4mm is lost in this 12.5mm anyway - so there is very little in it - as seen in Scarey's pics. Some of the later spec 20" FFFRR wheels have the RRS offset anyway and the 18" ones certainly did, so I don't think fitting RRS wheels is an issue other than visually, some of them look ok, others look awful, I think Scarey's look ok almost factory (ish) FFRR.
There was a post on here 3 or 4 years ago a gentleman had fitted the std RRS 19" wheels to his FFRR with GY Mud tyres and there were pics posted...
Post #67216 6th Jun 2011 12:04pm
