![]() | Home > Technical (L322) > RF Receiver |
Triumph72 Member Since: 11 Apr 2018 Location: Argyll Posts: 39 ![]() ![]() ![]() |
Could someone tell me where the RF Receiver is in the car? 2010 FF.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8808 ![]() ![]() ![]() |
It's under the rear spoiler, easy to remove, three 10mm bolts then get a friend to help so you don't scratch the paint...
Item 13...
Hi
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
Hi
Sorry for the late update, I've been away to a wedding. I still haven't found the module, I am going to
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2748 ![]() ![]() |
I assume that you're looking for the key receivers, not the radio. There are several located about the vehicle but there's a spot below the light switch IIRC where the key should be held if it's not generally working. Edit: Owners manual, starting the engine section shows where to hold the key if the engine won't start. |
Yes the key rf receiver, I know about the place to put the
Have you replaced the battery in at least 1 fob? |
Yes I renewed both fob batteries with duracells and, the car battery is fully charged.
The owners handbook technical section shows the locations of the keyless start module and the 4 cabin transmitters. |
