![]() | Home > Technical (L405) > Dead engine need to raise suspension |
| Martyn Member Since: 10 Mar 2013 Location: Poole Posts: 65
Turn the ignition on, no engine running, put the hazzard lights on and close the door, you can then hold the lights and unlock button on the keyfob to raise the suspension (providing there is enough air in the tank).
| Hodgey26 Member Since: 03 May 2022 Location: Perth Posts: 4
Thank you so much Martyn, this worked perfectly!! now to find out what has happened to this engine cheers |
