Home > Technical (L322) > Tow Bar Help Please
Page 2 of 3 <123>
beemer5711
Wales
Will do, thanks.
If replacing the whole thing, is it like to use same fixing points and the current one?
Also, any recommendations on a detachable one to go for?
Post #671723 22nd Aug 2023 8:52am
garyRR
The tow bars use all the same points as the existing, however you do need to replace the whole assembly which means rear bumper off and the exhaust silencer supported on axle stands.
There's only 2 or 3 tow bars made now for the L322, which makes the decision a bit easier.
Witter - this is a fixed tow bar and also has a lot of metal on show (good if you use it for commercial uses and need to attach tow ropes and all sorts but a bit unsightly for road use imo)
Tow Trust TL249 - fixed flange however the amarture is removable (2x bolts) - this is what I have
(I located the electrics on the underside for a more discreet set up. It came with the plate to install by the tow ball).
Tow Trust TL249VK / TL249AVK - as above, but the detachable tow bar
Steinhof - not really available in the UK
If you need/want to replace the electronics, the ECS loom is plug and play and very well made. 2015 Range Rover Autobiography 4.4 SDV8
Post #671729 22nd Aug 2023 9:11am
beemer5711
Wales
Thanks very much.
That’s really helped me out.
I think I’m going to replace it. I’ll test the electrics on a friends horse box and go from there.
Last question, is there a preferred supplier of the one you have?
Post #671789 22nd Aug 2023 7:57pm
Byg Nyge
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
Mine is the same as garyrr, Tow Trust, twin electrics on mine however as my caravan has the two 7 pin plugs.
It cost £400+/- fitted at Indispension Newcastle.
Mines a 2006 TDV8 so isn't plug and play.
Post #671790 22nd Aug 2023 8:07pm
garyRR
I'd contact Tow Trust with some additional photos first.
I'm relatively confident this looks like a Tow Trust bar. I expect they make them to a standardised size and if it is, they may be able to sell you just the detachable section or a replacement flange to fit.
Post #671791 22nd Aug 2023 8:21pm
beemer5711
Wales
Yeah, I'll give it a clean up and get in touch with them.
Im going to be new to towing on a caravan and using ball and pin. Lots of experience towing, but with a big towing pintle for big trailers/generators.
I just want to make sure it's not going to fall off the back haha!
If I don't replace whole unit, I will clean up in the slot where the swan neck sits do you thing this should be greased too?
Post #671792 22nd Aug 2023 8:46pm
beemer5711
Wales
Hi,
I think I have determined that it is a Witter detachable.
I have found one online for a Skoda Yeti, but the receiver for the swan neck looks the same.
I have contacted Witter asking if there is a part available to fit. In the mean time, can anyone else shed some light on it?
Here are some pics I took of the receiver and the one I found online.
Post #672113 27th Aug 2023 8:43pm
JavaBlack
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
I phoned my Local Witter Towbar Dealer who was extremely knowledgeable / helpful.
Post #672119 27th Aug 2023 9:13pm
beemer5711
Wales
Cheers, ill do that tuesday
Post #672120 27th Aug 2023 9:14pm
rover75lover
United Kingdom 2004 Range Rover Vogue Td6 Baltic Blue
silly question ,the adaptor isnt hidden in the cubby hide hole on the right hand side ?
well miracles do happen.
Otherwise try a range rover breaker ,bought one for mine for £150.00 . yes it isnt a detachable one but it fits works and was loads cheaper than the official westfalia adaptor plate id have to have
just an out of the box way of thinking
im welsh ,we're tight ,lol
my money is mine till someone wrings it out of me ,ex wife excluded lol
Post #672162 28th Aug 2023 3:14pm
JavaBlack
The detachable swan neck usually has a part number beginning with ZD (e.g. ZD3004) once you have this number I am sure a search on eBay will yield a result.
Post #672198 28th Aug 2023 9:03pm
beemer5711
Wales
I’ve looked and looked again. Not there unfortunately!
I’m also, in wales. Where are you based out if curiosity?
Post #672202 28th Aug 2023 9:34pm
beemer5711
Wales
Yeah, once I know what part I need, I’m sure I will be able to source one. I have no idea how old this tow bar is though, so might not be so easy.
Post #672203 28th Aug 2023 9:35pm
beemer5711
Wales
Hi again,
I tested the existing 13 pin socket today with a made up lighting board the caravan dealer has. All worked, but there was nothing in the dash to say it was using the socket.
In other cars I’ve towed with a there has been a separate light for the indicators, or an additional beep when indicating.
Should there be something think this on the 2012 L322?
I did read about it needing to be told it’s going to tow? Also might be because it’s just a lighting board and only the light pins are being used?
Post #672205 28th Aug 2023 9:39pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
The electrics look for the load of tungsten stop light bulbs to enable the car to know there is a trailer present. LED's do not draw enough current.
Once it recognizes the load, the indicator repeater will light up and the software will ask what type of trailer is connected.
Well, that's how my Westie seems to work anyway. Forty years of progress. 1972-2012
Post #672349 30th Aug 2023 7:52pm
Page 2 of 3 <123>
