Home > Technical (L322) > High beam LED and MOT |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1461 |
I think most MOT stations won't care, however I have previously had a car fail due to LED bulbs in incandescent fittings. 2015 Range Rover Autobiography 4.4 SDV8 |
23rd Aug 2023 8:32pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7772 |
I had no issue. Which ones did you get?
23rd Aug 2023 8:34pm |
Ennoch Member Since: 26 Dec 2015 Location: Scotland Posts: 109 |
Some MOT testers are more lenient than others. High beam and low beam are quite often different in how they're approached, and whether or not they're fitted within a projector or a reflector housing. A mate of mine is a tester and is certainly one of the more pragmatic ones, if not actually massively lenient. However, even he would fail an LED in a reflector housing. As long as it's not obvious (i.e it's in a projector housing) and especially if it's high beam, I can't see anyone but the most yellow jacketed power tripping tester to have any issue. |
23rd Aug 2023 10:24pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4295 |
Passed with no issues here. Old ones in the boot on the day in case needed to swap out Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
24th Aug 2023 7:20am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3162 |
Same as you recommended a while back I think I've got the old ones in the boot and may just pop them back in to avoid the (small) risk of a retest and another £12.50 ULEZ trip back to the garage.... 2012 TDV8 Vogue (L322) |
24th Aug 2023 7:36am |
Passed with the LED's 2012 TDV8 Vogue (L322) |
31st Aug 2023 7:35am |
