Home > Technical (L322) > Alarm gets triggered by the sun
Henrik07
Norway 2007 Range Rover Vogue TDV8 Santorini Black
Here's a strange one:
My 2007 tdv8 vogue triggers the burglar alarm whenever it's parked out in the sun on a warm day. It never happens in the rain or if there's a fairly dense cloud cover, but if the sun peeks through for more than a few minutes, off it goes.
Now, I covered what I believe to be the motion sensors up with tape (front and rear of the dome light cluster), but that didn't make a difference.
Any ideas? Is there a way to know which exact sensor was triggered?
It's been going on all summer and it's a nuisance.
Thanks!
Post #671840 23rd Aug 2023 2:46pm
its probably the bonnet getting hot and setting the sensor alarm off..disconnect it and see if that helps.. ... - .- -.
Post #671842 23rd Aug 2023 2:53pm
Henrik07
Thanks.
I did consider this, as I have read that the bonnet switch is a common failure, but mine is a 2007, so post facelift model, and it doesn't have that switch poking up from the battery box. Neither have I ever had a "bonnet open" warning whilst out driving.
Do you know where that switch moved to, if I wanted to try your suggestion? It seems to me it would have to be on the latch somehow, hidden from view and access.
H.
Post #671843 23rd Aug 2023 2:58pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
On my 2011 Supercharged I had exactly the same a year or two ago, the alarm going off (thinking the bonnet was open) on super sunny days. On mine the bonnet switch/plunger is on the opposite side to the battery. I ran with it disconnected for several months until I next placed an order for parts (as the switch itself cost less than the postage I think!), but did then fit a new switch and it's been absolutely perfect again for the last year or so.
Post #671867 23rd Aug 2023 10:21pm
Henrik07
I've been nosing about under the bonnet looking for that switch, without success. However, if your 2011 has the simple plunger, I'm stumped to figure why they would do it differently on the diesel. Seems as if some more nosing around is called for. It's not as if there isn't room for it under there....
Mine is a lhd 2007 tdv8. If anyone knows the exact location of the bonnet switch, please enlighten me Smile
Thanks!
Post #671868 23rd Aug 2023 10:30pm
Henrik07
I found it. It's been staring me in the face this whole time. Unplugged it now, so we'll see how it goes.
Thanks!
Post #671936 24th Aug 2023 5:50pm
mjdronfield
If it’s still the plunger, bend the bracket up so it’s nearer the bonnet or put a grommet or similar on the end to make it a bit longer, though obviously if you unplug it, it will prove that it’s the issue.
Might not be faulty, just a bit too low when the bonnet heats up in the sun…
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #671939 24th Aug 2023 6:25pm
Henrik07
Thanks. I read that tip before, which is why I went looking for the switch in the first place. It's all a very plausible explanation, with one major flaw: I never got a random "bonnet open" warning when the car was running - not once. It still remains the most likely culprit, but I'll just have to see. Typically, It's now cloudy with occasional drizzle and no warm and sunny days ahead. I may have to wait until May '24 before I can close the book on this one... Razz
Thanks again, everybody!
Post #671961 25th Aug 2023 7:27am
mjdronfield
I didn’t get a bonnet open when running either.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #671968 25th Aug 2023 9:07am
