![]() | Home > Technical (L322) > ODB PID for DPF soot level |
jtq4u Member Since: 23 Aug 2023 Location: Portsmouth Posts: 37 ![]() ![]() ![]() |
OK everyone I am excited to say I have found out the PID. What I did is install a car OBD emulator (which makes my laptop pretend to be a car with an OBD socket)
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4342 ![]() ![]() ![]() |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3864 ![]() ![]() ![]() |
Very clever, watching with interest.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3308 ![]() ![]() ![]() |
Why do you need to monitor the soot level unless you have a fault? 2012 TDV8 Vogue (L322) |
I think of it as DPF management and use the iid at least once every couple of weeks to check soot concentration, then either take it out for a long run or force a regen before it alarms.
I leave my DPF to manage itself. Never had a warning light in 2 years. 2012 TDV8 Vogue (L322) |
I am thinking I might be able to trick the car into displaying the soot level instead of the temperature outside, when button is pressed. That might be cool |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
Was thinking about the temp thing on the display - would that work?
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
My thoughts also. Much like any other of the car's monitoring systems, they're designed to only let you know when there's a problem, otherwise the dash would look like a power station control room. 2015 Range Rover Autobiography 4.4 SDV8 |
Perhaps you are right we don't need to know, though across the various Range Rover forums I am on I see so many people having issues with their DPFs. A lot stem from the failed Regens - as of course the vehicle doesn't know when a journey is going to be long or not. If we knew when the dpf was approaching full and triggered the regen at the start of said journey there would be a lot less failed regens.
Yeah you might be right that a seperate guage would be best. My other thought was to replace the analog clock with one - as I am happy with the digital display one, and the extra one in my android-auto display that I replaced the top-dash vents with. If i were using the temperature display, I was planning to intercept it at the temperature variable resistor it self (simulate temperature resistances).. so that in fact the origional method of inserting the messages on the bus remained. |
' failed ' regens only happen if you have a fault and the system doesn't start it. Partial regens are fine as it removes some soot load. 2012 TDV8 Vogue (L322) |
Agreed but on the L405 each attempt appears to decrement the service interval irrespective of whether it completed. Thus the time between services plummets. V8 or else ... |
I am not sure if they count as partial if they get aborted during the preheat phase, from my observations I think not (which would make sense as they achieved nothing). It takes a reasonable amount of time after the beginning of the regen before the soot starts going down. Once it goes down it goes down pretty fast. I have some partial, some successful, but a lot more requested. The delta between requested and (partial+successful) I assume to be the ones where I have arrived at work before the soot started going down. All regens, partial, complete.. or aborted before the soot count goes down, cause the oil dilution. The ones that are fruitless (we didn't get to the soot burning temperature) are of course still squirting fuel on the exhaust stroke.. and leaking diesel into the sump.. Therefor if you take a lot of journeys that are not long enough for the pre-heat then you will end up with a lot of wasted dilution, as the car doesn't realise the journey isn't going to be far enough. even worse sometimes the journey might have been long enough but the soot level reached the magic number (about 22g/m) towards the end of the journey. If I had requested it early (say when it was at 17g/m) at the start of the journey then it would have been able to complete, or at least get some partial success. A non informed choice of time to start regen is always going to lead to more fruitless regens. I think it is less critical with newer cars, as there is more capacity in the DPF, but as the DPF ages and capacity reduces they need more frequent regens.. which gives more opportunity for badly timed ones. Also partial regens are going to cause more frequent oil changes too.. as each regen takes the same amount of fuel to pre-heat the dpf. So if you require two partials to acheive full regeneration you will pre-heat twice and leak double the fuel into the sump. Therefor if the 12,000 mile service interval is based on all successful regens, we could potentially with a 3,000 mile service interval if you have 50% badly timed regens and another 50% partials. (so 1 pre-heats needed for a single full regen). |
