![]() | Home > Technical (L322) > Suspension |
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 101 ![]() ![]() ![]() |
Mine 2007 Vogue did similar things awhile ago it turned out to be the air tank under the sill. It was rusty and leaking so couldn't keep enough pressure in. However before I realised that I changed the air compressor because it had failed due to running constantly. The tanks changed from aluminium when BMW were in charge to mild steel when Ford took over. Borrowed Grey 2002 3d 204k for a year
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7966 ![]() ![]() ![]() |
As it’s saying close door…. It thinks a door is open so locks out suspension movement. I get the tank could be an issue, as mentioned above, but why would that make it think a door was open?
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 798 ![]() ![]() ![]() |
I'm with MJ on this! The car thinks a door is open, ergo it won't raise/lower. Simples....ish! Just need to find out which door is causing the issue and rectify it. |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 761 ![]() ![]() ![]() |
Well, well!
