Home > Maintenance & Mods (L405) > 2017 L405 ACE Drop Links/ARB Bushes
JamboM3
Need to replace the drop links all round on my 2017 4.4 SDV8 that has ACE.
Does anyone know the part numbers I need? I have seen two options and not sure which one applies to my car - it is fitted with the ACE anti roll bar system.
Be looking to replace the links as well as D bushes
Post #671881 24th Aug 2023 7:49am
MarianaWestminster
The links themselves are common between cars with/without ACE.
Not sure on the D bushes but I'd imagine those are specific to the ACE bars.
Post #671902 24th Aug 2023 10:42am
Fifth Horseman
The bushes for the ACE equipped vehicles are different - MY18-on are also slightly different again.
Its also recommended to replace the nuts and bolts
Front links LR035489
Rear link LH LR048093
Rear link RH LR166064 (was LR048092)
If you use genuine drop links IIRC they don't come with the nuts so you will need 8x FY114056 (M14 flanged nyloc) all the aftermarket ones I've seen do have the nuts.
Front bushes LR110782 (up to MY17 chassis no. HA999999 - LR048451)
Bolt 4x LR050753
Bolt 2x LR045743
Nut 4x FY112056
Rear bushes LR048462
Nut 2x FY112056
Bolt 2x LR033245
When replacing the bushes make sure the bar is clean where the bush goes else it will creak, also if someone has been at the front before you it is possible to strip the threads in the aluminium subframe where the roll bar support bolts to, repair inserts are available - DAMHIK Embarassed
Post #672041 26th Aug 2023 9:18am
Mikey
Been there, done that. Not fun Banging Head
Even less fun when it's the subframe mounts Shocked
Post #672054 26th Aug 2023 11:45am
JamboM3
That's great thanks chaps!
Will be ordering this week. My local indie will be fitting so thankfully I will be saved the headache.
Looking forward to this tightening up the front end, just trying to decide if I should do the rear at the same time
Post #672232 29th Aug 2023 7:46am
JamboM3
All fitted - knocking gone and a huge improvement on the drive! Thanks all
Post #673641 17th Sep 2023 9:34pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
Did you do the rear?
Did you use genuine or aftermarket links up front? Genuine are $100 CAD each, Delphi are $20 CAD. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #673706 18th Sep 2023 3:22pm
JamboM3
Used aftermarket, these are fairly common on RR’s and basic tech, so I didn’t see the need for the added OEM expense.
Used Febi, links + D bushes front and rear
Post #673707 18th Sep 2023 3:34pm
Bora20
Thank you. I replaced my fronts previously with Mevotech. The “may” be part of the knock return. I will try Delphi next front and rear. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #673708 18th Sep 2023 3:36pm
JamboM3
Think Delphi are a decent brand for this application. If you can get Febi Bilstein in CA then so far so good!
Post #673717 18th Sep 2023 5:34pm
Bora20
I had trouble getting the previous ones to torque. I had to use vice grips on the backside collar to reach 185nM. Maybe the Delphi will be better and won’t spin all the way to torque. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #673751 19th Sep 2023 2:05am
JamboM3
Word of warning if anyone finds this via search.
Febi parts failed within 4000 miles and 8/9 months of use. Caused a terrible knocking noise that would randomly appear then disappear over that time. Garage removed them and said they were toast.
Replaced with genuine Land Rover parts - no more noises.
Post #694342 12th Jun 2024 11:19pm
Bagus
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Loire Blue
How stiff were the LR drop links? I’ve bought a set and the ball joints are very easy to move around with one hand but was expecting them to be very stiff. 2016 5.0 Loire Blue
2002 4.4 v8 Adriatic Blue
Post #710804 2nd Feb 2025 1:26am
Jaws_RR
2016 Range Rover Vogue SE SDV8 Loire Blue
Hi, I just bought my first Range Rover and am in the middle of renewing the suspension. Previous owner ran it on a shoestring. Do I need new brackets and bolts or can I just replace the rubber D bushes? Thanks.
Post #713007 28th Feb 2025 3:14pm
If you are talking about ARB mounting bushes then you can reuse if they are not badly rusted and weakened.. the original bushes are stuck to the bar so you have to cut it all off...
Fill out your car details in your profile and you will get a little car in you side bar, hover over it and we can all see which model you are talking about...
Also best to make your own threads when you need help, piggybacking off old posts isn't a good idea... Thumbs Up Pete
Post #713031 28th Feb 2025 9:00pm
