![]() | Home > Maintenance & Mods (L322) > MOT Advisory on Brake pipes |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 232 ![]() ![]() ![]() |
I know if I had an advisory for corroded brake pipes I’d get them replaced asap. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3835 ![]() ![]() ![]() |
+1 ditto
Why would anyone risk not fixing an issue with a crucial item like the brakes..... 2012 TDV8 Vogue (L322) |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
Just get them changed.
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1230 ![]() ![]() ![]() |
My rear brake lines failed a recent MOT due to corrosion. It was a nightmare getting anyone to do the job. Took it back the MOT garage and whilst they were checking out the brakes again the lines popped! From what I have been told it is a very common weakness on the rears especially near the flex lines.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Mine failed during the MOT test on the rollers. I had them replaced with Kunifer 10 brake pipes which should have been standard fit from JLR. To fit standard brake piping to a premium car that's designed to wade through water is crazy, Kunifer corrosion resistant brake pipes don't cost that much more. BMW i3 Electric Car
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
I had an advisory on brake pipes few years ago and replaced with Kunifer, I seem to remember a 7.6 metre
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 476 ![]() ![]() ![]() |
I didn’t have any advisories for the brake pipes on my 2004 FullFat but one day the pipe which crosses from the left rear nearside to the right rear decided to split.That was a fun day…..
rover75lover Member Since: 02 Aug 2021 Location: wales Posts: 13 ![]() ![]() ![]() |
my 2004 had advisories going on the front pipes . Changed them ,tried the brakes and whoosh lost all pressure resistance . Had brake pipe fluid all over the sill ,removed the plastic and wow accident waiting to happen ,all with rot ,one had burst . Changed the lot .
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 151 ![]() ![]() ![]() |
I had an advisory on brake pipes last year but no mention of them on this years mot by the same garage? RR owner |
Just ignore it and don't worry then - maybe the rust has cleared up all by itself? 2012 TDV8 Vogue (L322) |
Either way thats a scary thought that they haven’t been changed. |
& they live on the same planet as us.............. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1409 ![]() ![]() ![]() |
My 322s had this, the 2004 one failed its MOT on corroded brake lines. Based on mine, there is probably surface corrosion but if failure were imminent it would have failed. Clearly you can't go wrong just getting the work done. But maybe step 1 is to discuss with the tester what sort of life is still in the lines. On one occasion mine were treated with a rust inhibitor like Dinitrol (not sure which) and with that treatment they lasted a while longer. But as a general comment 322 brake lines are not especially durable and one has to be prepared to replace etc from time to time. Only Range Rovers since 1988 |
