Home > Maintenance & Mods (L405) > Six Pot Callipers
Six Pot Callipers
My front callipers are about a year old... it looks like they have melted.... only looks like, they haven't really but the finish seems to have suffered.... anyone else had this, could it be TFR used by car washes...
I feel like a repaint coming on...!! Pete
Post #672126 27th Aug 2023 11:13pm
Phoenix
Yep, it'll be the 'wheel cleaner' mine have bands across them where the spokes have masked the calipers, I'm planning on using https://www.amazon.co.uk/TechniQ-Thunder-C...B07QXSN7KK with a replacement hold-down kit. I also use Sonax wheel cleaner which doesn't attack anything and everything else...
https://www.amazon.co.uk/dp/B094J43WC4
Post #672127 27th Aug 2023 11:29pm
Just had this delivered, used it before and like the finish, should look near original... Thumbs Up
https://www.amazon.co.uk/TechniQ-Thunder-C...&psc=1 Pete
Post #672141 28th Aug 2023 11:16am
knwatkins
I used the same paint on mine a few years back. They came up really well and still look perfect today.
 Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #672159 28th Aug 2023 2:40pm
Phoenix
What did you clean them with prior to painting? I've only ever sent them away for refurb with someone else paying, I'd imagine a heady mix of brake cleaner brass wire brush & Scotchbrite?
Post #672164 28th Aug 2023 3:19pm
I've just used neat TFR in the past, a good rinse then brake and clutch cleaner... red scotchbrite and a very light coat of acid etch primer, I then paint the faces in high temp silver, use a cut vinyl logo on top, coat the whole thing with the Thunder grey, remove the sticker to reveal the logo in silver the clear coat the lot with high temp... seems to last a good long time.... Thumbs Up
Think I may go with a "Range Rover" logo instead of the "Brembo" one this time... Pete
Post #672177 28th Aug 2023 4:51pm
Phoenix
Hmmm.... I might relieve our wishy-washies of a litre or so of wheel cleaner, that should 'bite' the brake dust a bit better than TFR. I'm not sure about the logos - but your way of masking is much better than leaving the stickers in place, which is what most do, that and 'colour coded brake pads'!
It's also as good an excuse as any to do a brake fluid change Thumbs Up
Post #672180 28th Aug 2023 5:17pm
I get the TFR from a local cleaning place, it's supposed to be diluted 100:1 to clean HGV chassis...
Neat it removes everything and has to be carefully used, and rinsed well, it's better than any wheel cleaner I've used.... Thumbs Up Pete
Post #672197 28th Aug 2023 8:48pm
Phoenix
From what I remember, TFR is acidic, wheel cleaner is alkaline (possibly the other way around) one of them lifts burned-on brake dust better than the other but either will do the job in it's 'diluted less than specified' form. The wishy-washies at work know not to use wheel cleaner on my car, usually because I've already sprayed Sonax on them - which turns the brake dust blood red! the TFR is sufficiently diluted to have minimal effect upon anything, least of all the 'TF'....
Post #672199 28th Aug 2023 9:04pm
It cleans well but yeah, dodgy stuff, I think it's alkali, I used it neat on some old filthy wheels that were beyond saving, left it on for 10 mins and it etched the surface and the wheels ended up matt finish..
Never used that, make it red stuff, Looks good... Thumbs Up Pete
Post #672212 28th Aug 2023 10:38pm
Im Loving the Union Jack look right now Peter...
Post #672219 29th Aug 2023 12:13am
JamboM3
The standard finish looks like the cheaper anodised finish some OEMs use. On my L322 these had turned literally white from years of harsh chemicals.
As suggested, paint them. Best thing I ever did on my L322. Then ceramic coat them, after this you are unlikely to need anything other than regular shampoo to get them brand new.
TFR is highly acidic and will eat into the coating, avoid using this. Any number of wheel cleaners available now that are PH Neutral. IF you have build up, consider using a ferrous cleaner like Iron Out or any of the other traded fall out removers, this will strip the brake dust and then you can clean off the gunk with a mild wheel cleaner or degreaser.
Craig: Those look FAB!
Post #672233 29th Aug 2023 7:50am
Craig, shame to put the wheels on and mask some of the callipers, they look ace.... Thumbs Up
JamboM3,
It's persuading the local Polish car wash that they should use something more suitable that is the problem...
Numerous screws and wire fixing a broken back, extensive nerve damage, two replacement hips and a new knee mean my days of cleaning wheels is long gone.... Shocked
I'll paint them with that hi temp paint (on a mates two post ramp) and they should survive a few years of car wash abuse.... Thumbs Up Pete
Post #672238 29th Aug 2023 9:14am
caymanblack
Those Aston Callipers look great! overfinch modified
Post #672239 29th Aug 2023 9:51am
they do indeed.....but not on a range rover Mr. Green ... - .- -.
Post #672243 29th Aug 2023 10:54am
