![]() | Home > Technical (L405) > Many issues |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35765 ![]() ![]() |
i would get that battery properly checked out..it could be the cause of your problems .. ... - .- -.
madasmad Member Since: 22 Mar 2020 Location: Cheshire Posts: 89 ![]() ![]() ![]() |
Thanks Stan 2019 Autobiography SDV8 Byron blue/black - current
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3239 ![]() ![]() ![]() |
there is a second battery in 405s isn't there? I had a second battery in my 322 and it drained the main battery causing totally engine stop etc. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
The 405 has a BMS system that keeps the two batteries separate until needed, apparently one flat one can't pull the other down but that's in theory...!!
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1777 ![]() ![]() ![]() |
@madasmad:
Just an update -
Did you check battery SOH, as Stan advised?
Thanks Gremlin |
So, after 10 days at LR Stafford - who have been great - they have fixed the following:
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 536 ![]() ![]() |
DDo these have to be used on the battery terminals or can they be used as effectively on the under bonnet posts? Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black. |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1168 ![]() ![]() ![]() |
Bloody hell mad who is the crappy dealer you bought that from, disgraceful. overfinch modified |
Hi madasmad,
It will (among many other things) tell you battery % remaining SOH (state of health) compared to new (not just SOC state of charge) -mine was a pitiful 29% last year before I replaced it, even though the car was still starting OK, -probably due to being plugged into a CTEK most of the time. It only takes a few minutes to complete a scan. If you end up needing a new battery, Tayna are very good, I got one of their own “Enduroline” AGM ones which came with a 5-year guarantee at a good price and fast delivery. V6 Vogue - “Less is More” - less to go wrong! |
