Home > Technical (L322) > lights
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
lights
Hello everyone
Often the messages "check real fog light" or "Check side liggt" appears on my dash. I go and check the klights and all are OK. What can be the cause of these messages?
Thanks all
Post #672310 30th Aug 2023 10:25am
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
Sometime working, sometime not. Bad connection or something...
Post #672325 30th Aug 2023 3:30pm
Take the respective bulbs out and clean them with fine emery paper, probably minor corrosion.
Post #672329 30th Aug 2023 4:12pm
TDV8 Paul
Sometimes these can warn you of a bulb is on its way out, the filament might be intact but the car is not detecting the correct voltage coming back because the filament is dying and causing extra resistance on the circuit 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #672338 30th Aug 2023 6:30pm
TDV8 Paul
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #672339 30th Aug 2023 6:30pm
