Home > Maintenance & Mods (L322) > Anti rust treatment.
Byg Nyge
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
About to book my '06 Vogue SE TDV8 (3.6) in for Dinitrol rust treatment and preventatine coating, apparently they drop the subfames to do them all over and get to the underbody, takes 3 days as they have to let the rust converter cure the apply the protective coat. Cost about 1k. Anybody on here had it done? Any good?
Post #672158 28th Aug 2023 2:03pm
darrenm
I have had my 2009 /59 reg since 2012 and have always used Lanoguard and it’s still mint
Post #672193 28th Aug 2023 8:16pm
Baltic Blue
I had my 2011 4.4 tdV8 treated at a Dinitrol centre 7 years ago , but it definitely didn’t involve lowering the rear subframe in any way.
All the plastic under covers, wheel arch liners and cills were removed, the whole lot steam cleaned and then treated.
Every year the MOT men mention how good it is underneath, and I certainly recommend getting any car you intend to keep long term treated with Dinitrol.
Post #672201 28th Aug 2023 9:17pm
Phoenix
Dinitrol is good stuff, if you want to check what goes where (they may charge extra for application of RC 900) then spend £20 on the spray diagram https://www.dinitroldirect.com/product/veh...ay-diagram
Post #672210 28th Aug 2023 10:04pm
DrRob
Lower the subframes? They are pulling a fast one on you!
I'm a Lanoguard convert. Much easier to apply (albeit annually) but takes a fraction of the time of other stuff. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #672235 29th Aug 2023 8:00am
Byg Nyge
Got it totally wrong about lowering the subframes DOH, on Discos and L320's at the place I'm taking mine they take body off, clean off the lose rust and the use the rust converter, when that's dry they coat with Dinitrol. On the L322 they remove the under body panels and treat it as above. While its in I'm getting diff and transfer case oils changed and a gearbox flush and oil change plus a couple other jobs that need doing. Vacuum pump seal, rear discs & pads and handbrake adjusters, OSF bottom arm, dunno which one as the previous garage did not specify. Hopefully that keep it sorted for a bit!
Post #672340 30th Aug 2023 6:41pm
TJH1985
I have moved over to Dynax from bilt hamber as I find it much easier to apply than lanolin based products as it doesn’t run it also longer lasting.
My experience with Lanoguard was underwhelming I found it had almost gone after 6-8 months in some areas compared to Dynax which is holding strong way past 12 months.
You can beat a proper dintrol IMO but it’s allot of work.
https://bilthamber.com/product/dynax-uc/
I’ve just done the transporter in it a mix of brown and clear and it looks OEM:
 MY17 Santorini Black L494 Autobiography 5.0 SC - Sorry!
Previously Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #672341 30th Aug 2023 6:50pm
Ennoch
I've not been impressed with Lanoguard (edited as I'd originally said 'Lanolin') on the cars I've seen it on. It's better than nothing but I notice they now call it an annual thing which they weren't doing when they started with their heavy social media marketing presence. I'm not sure who their backers are but they seem keen to buy up significant market share. Personally I only use Bilt Hamber stuff as it stays put very well, as long as you use the UB rather than UC. I prefer UC on restored classics as it keeps fresh paint looking nice and clean rather than the dirty brown the UB is, but that's personal.
A small point of note though; Bilt Hamber Dynax of all varieties is also lanolin based. I've had people argue with this on a few forums but having talked at length in person with Peter Hamber who owns the company about this I'm willing to believe him.
Post #672352 30th Aug 2023 8:02pm
Everything I’ve used lanaguard on has worked brilliantly! 👍
Post #672362 30th Aug 2023 8:29pm
TJH1985
That’s some good info, I hadn’t even considered what it was beyond a wax I use the UB on anything that is dark and the UC on everything else purely from a cosmetic standpoint.
I buy it in 5L and use one of these: https://www.sealey.co.uk/product/563719852...jector-kit which I wish I had brought years ago as it makes life so much easier!
Not as good as dintrol, but I don’t mind topping it up annually it’s that easy. MY17 Santorini Black L494 Autobiography 5.0 SC - Sorry!
Post #672364 30th Aug 2023 8:34pm
