![]() | Home > Technical (L322) > ABS fuse keeps blowing up |
Then it will be a component connected to the same circuit and in the same group - yaw rate or steering angle sensor for instance. Check the wiring diagram to see what else the fuse also supplies. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2678 ![]() ![]() |
According to the wiring schematic that fuse only supplies the ABS module. I would look for chaffed wires between the aux fuse box and the ABS module on a loom section that can move. The bundle is 1.5M long.
albertocsm Member Since: 14 Mar 2023 Location: Aveiro Posts: 8 ![]() ![]() ![]() |
can you please point me to the wiring schematics?
I don't recall from where I got my diagrams but here's the auxilliary engine junction box.
๐๐๐ |
GraemeS, do you know if there is a relay for the ABS module?
The wiring schematic doesn't show any relays between the fuse and the ABS module.
