![]() | Home > Technical (L322) > access mode |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
I always lower when coming to a stop except when it is getting washed as I see it as giving better access to the wheel arches etc to get rid of any crud or mud. John
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
Always drop to access mode, just before stopping & as Kevinp stated. |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
Am not sure if this is as designed
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8808 ![]() ![]() ![]() |
If you are not parked on level ground then the fatty will try to level itself after being parked, it does it by dropping the high corners, it doesn't add any air....
The self levelling after exit is normal, after all, you've just removed several tens of kilos from the vehicle so it will rise from it's previous height as you get out.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Lower mine with the door button every time. Press it as you’re slowing down to stop. Will be done by the time you stop and before any door openings. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
landy95 Member Since: 04 Aug 2021 Location: West Midlands Posts: 86 ![]() ![]() ![]() |
I wonder how dropping into access mode and leaving for excessive time affects the suspension bushes as when they are fitted they are locked in place when at normal height so no load. I guess sitting at access height with a torsional load on them must reduce their life. Just a thought. Also own a 1976 Land Rover 101 3.5 V8.
Self levelling would be it! I park on a reasonable slope |
