Home > Maintenance & Mods (L322) > Lost airpod!
Snowy90 L322
United Kingdom 2019 Range Rover Vogue SDV6 Baltic Blue
Lost airpod!
Ok so not a major issue to me! But to my daughter she apparently has had her life shortened.
She dropped one of her air pods down the seat belt socket in the seat. Then proceeded to try and get it out to which it completely disappeared!
Now I'm sure its inside the seat base. Which if it helps is the double nearside seat base. Its a 54 plate L322.
So is there an easy way to get inside the seat, the carpeted base seems to be very well fitted with some black fir tree type clips. No obvious way or opening it up.
Please help with any advice!
Post #672680 4th Sep 2023 11:37am
Ennoch
A few possible options here. Does the remaining AirPod stick to a magnet on a stick? If so, use a flexible one and have a poke about, there's only so far it can have gone. The other is that you could use a small endoscope (they're cheap on eBay and a handy tool to have) to see where it's gone and then use a claw to grab it (I've got 600mm long flexible magnet with a claw on the end that's very useful when you've dropped something in the engine bay, or worse). I'm unfamiliar with pulling the seat apart though. Good luck finding it either way!
Post #672711 4th Sep 2023 11:20pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
You could first try your luck by removing the plastic hinge cover. It's held in place by 3 philips screws. Then perhaps you could shine a torch and try to fish the airpod out with a cloth hanger wire or something similar. Happy fishing Thumbs Up
Post #672724 5th Sep 2023 10:36am
Snowy90 L322
All of these great suggestions, ill have a try before i go removing seats!!!
Post #672728 5th Sep 2023 11:09am
vs322
Good luck! Hopefully you won't have to remove anything more than the plastic trim. It has a tab that hugs the latching mechanism; don't be afraid to force / bend the whole thing. It might be more of a pita to refit and leave you with two sore index fingers though. Ask me how I know Whistle
Post #672729 5th Sep 2023 11:27am
