Home > Maintenance & Mods (L322) > Front differential drain/fill plug sealant... Loctite 574?
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
Hi everyone,
I'm preparing to replace the fluid in my front differential and the manual specifies to coat the fill plug and drain plug with a sealant before installing. But, they don't specify what sealant.
Earlier in the manual they specify to use Loctite 574 between the two casing halves.
Is this the same sealant to use on the fill and drain plugs?
Thanks!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #672760 5th Sep 2023 8:37pm
Phoenix
You could, might be difficult next time you want to change the oil though, I use Loctite 577 (liquid PTFE) with no issues.
Post #672761 5th Sep 2023 8:44pm
lschwarcz
Hi Phoenix,
Thanks for the info!
Would PTFE tape (used for water pipe connections) work for this?
I can't find the Loctite 577 locally but I can find Permatex 59214 high temperature thread sealant. I'm thinking this should be OK.
Any thoughts?
Thanks!
Bournville/Ivory
Post #672762 5th Sep 2023 8:53pm
lschwarcz
HA! I just answered my own question. Yes, they are equivalent products. The Permatex website has a Product Cross Reference page (https://www.permatex.com/contact/cross-reference/) that shows the two products can be interchanged.
Thanks everyone!
Bournville/Ivory
Post #672763 5th Sep 2023 9:02pm
Phoenix
Pretty much any good quality liquid PTFE will be fine, I get the Loctite supplied at work hence the referral.
The advantage of liquid over tape is that you can't overload the threads with liquid, using too much tape can result in damaged threads or hairline cracks in alloy castings - that won't happen with a quality PTFE liquid as the viscosity is within specific limits.
Post #672765 5th Sep 2023 9:28pm
Larry, why not order a brand new filler & drain bung? They come with the correct sealant installed and ready to fit... Thumbs Up
Post #672779 6th Sep 2023 12:23am
lschwarcz
Hi Cam-Tech-Craig,
Yea, I could but I'd like to get this work done tomorrow (well, yesterday but tomorrow from when I asked the question Very Happy).
I found the Permatex sealant at a local auto parts store and did the work tomorrow (actually yesterday).
Thanks!
Bournville/Ivory
Post #672913 7th Sep 2023 4:01pm
