Home > Technical (L322) > Adaptive dynamics fault light on but suspension still works
KennyT
2007 Range Rover Vogue TDV8 Atacama Sand
Hi All,
2011 4.4 TDV8 with 135k miles.
Adaptive Dynamics Fault appears on the dash immediately on start up but the height control still works on all settings. No loss of height overnight and drives just fine.
I have repaired wires on top of struts on both sides in the past and all airbags and struts have been replaced this year.
Any ideas what could cause the warning light to come on
Thanks in advance
Kenny T
Post #672881 7th Sep 2023 10:54am
mjdronfield
Adaptive Dynamics is separate to the air bags and suspension height stuff.
I’d say the strut wires, but if you’ve done them recently prob not the issue. Have read some have issues with the wires to the rear shocks, but not that many.
Are the shockers ok? No massive leaks. One of my originals split, but don’t think it threw an error.
Has your suspension gone rock hard now? Could try pulling all 4 wire connectors off the strut and putting back on?
Might need codes read unless more knowledgeable folk have some ideas….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #672883 7th Sep 2023 11:16am
ttrw2
Mine did this yesterday when I started it, and suspension was very stiff for first few miles. Stopped and restarted and been fine since. I put it down to the very high ambient temps.
Same as OP - strut top wires replaced too
Post #672885 7th Sep 2023 11:24am
JayGee
As said recheck the wiring but a scan with a GAP IID tool will likley be the best way of identifying the exact location of the problem. 2012 TDV8 Vogue (L322)
Post #672886 7th Sep 2023 11:24am
KennyT
Rechecked and stripped previous repair and found the cracked wire. Have now replaced a section with new wire, soldered and protected with heat shrink so probably good for a while Very Happy .
Thanks for all the fast replies 👍. Love this website
Post #672889 7th Sep 2023 12:07pm
What you have to bare in mind is that the top of the strut that the wire comes out from rotates when you steer. To do a successful repair you have to use very flexible wire and heat shrink and keep the heat shrink to a minimum... also don't secure the wire to tight, you have to allow it to rotate....
Start the engine with the bonnet up and get someone to do a lock to lock and you will see what I mean... Thumbs Up Pete
Post #672894 7th Sep 2023 1:19pm
KennyT
Thanks Pete. Makes sense 😉
Post #675375 12th Oct 2023 9:40am
GraemeS
Australia
I removed the cable retaining fitting from its hole to allow the cable more freedom to move.
Post #675384 12th Oct 2023 11:07am
KennyT
Is that the rubber like grommet?
Post #675389 12th Oct 2023 12:45pm
Phoenix
Soldering isn't going to be a long-term repair on a moving electrical harness, it will create a non-flexing section which will in turn mean that the wire strands either side have to move more and will therefore fracture sooner.
Better to de-pin the connector housings, replace a significant length (200mm or so) of Hi-Flex or similar, right from the connector pins to some point where the harness is fixed to the body using heatshrink covered crimp terminals, then protect with some flexible conduit which will control the flex and spread it out along a greater section, increasing the longevity.
Almost all automotive electrical connections are crimped, not soldered (soldered connections tend to be crimped and soldered) for very good electrical & mechanical reasons - and have been for some time.
Post #675391 12th Oct 2023 1:20pm
GraemeS
Australia
No, not the fitting in the vibration damper, instead the clip that restains the cable some distance from the damper which then allows much more length for the movement that occurs when turning.
Post #675448 12th Oct 2023 8:47pm
