Home > Technical (L322) > Glovebox light
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
Glovebox light
Bought a LED interior upgrade kit and noticed the glovebox light is missing, most of the vids I have seen show the older models that have the on off plunger switch attached to the light itself.
I have a 2010 and it looks like the on/off plunger switch is attached to the top of the glovebox assembly and not the light itself. Can anyone confirm this or is the plunger on mine is to drop the glovebox cover when you press the button to open it.
Post #673051 9th Sep 2023 8:12pm
tj196443
Photos added
Photos attached
Post #673052 9th Sep 2023 8:40pm
tj196443
Post #673053 9th Sep 2023 8:41pm
RJPotts
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Re: Glovebox light
That plunger is indeed the on / off switch for the lamp. The opening is via a solenoid on the latch. 2010 Range Rover Autobiography TDV8 Santorini Black
2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone]
2003 Range Rover HSE Oslo Blue [Gone]
1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone]
1990 Camel Trophy 127 (Workshop Vehicle) [Gone]
1989 Camel Trophy 110 (Workshop Vehicle) [Gone]
1998 Camel Trophy Freelander (South African Team Vehicle)
1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone]
Post #673570 17th Sep 2023 10:48am
tj196443
Thanks for the info, most of the lamps I have seen for sale have the on off plunger on the light unit itself. Those must be for the earlier models I guess.
Post #673575 17th Sep 2023 11:52am
garyRR
You can carefully remove and replace the bulb with a pair of long nose pliers. On a 2010, the bulb is a W5W. 2015 Range Rover Autobiography 4.4 SDV8
Post #673649 17th Sep 2023 11:40pm
