![]() | Home > Maintenance & Mods (L322) > Semi-overheating issue Tdv8 4.4 |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3382 ![]() ![]() ![]() |
I'd suspect the thermostat but check for parts availability before you tackle it as there was a serious shortage earlier in the year ( mine failed open). You can't buy just the thermostat either an you need the whole coolant mixer box but you can just then swop out the thermostat and housing (3 and 4) to avoid removing the whole box.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I did find just a thermostat available on eBay…. Did you swap out just the stat, or did you replace the whole unit… can you remove the old one from the housing?
Had to replace the whole lot but then found out it's possible to just replace the housing and thermostat although the screws were very tight.
What were your symptoms to necessitate the change please…. I’m sitting here trying to reproduce the fault… I’m getting fan roar at idle and when driving with AC on but fan goes ‘off’ when heater put on and AC obviously off. Car idles higher with AC on etc. |
Mine was the opposite - slow warmup in winter and temps dropping when moving faster / more rad airflow. As on the pic the thermostat seal had failed and was leaking coolant 2012 TDV8 Vogue (L322) |
Do you have a GAP IID tool and if so look at the coolant temp in the live values which should be 89/90 deg. 2012 TDV8 Vogue (L322) |
