Home > Maintenance & Mods (L322) > Best source for discs, pads and service items
joel-h
England 2010 Range Rover Vogue TDV8 Ipanema Sand
Hi all,
I'm shortly to do discs and pads on my 2010 TDV8. Where are people heading for decent prices on OEM parts?
Also, is there a reference for a list of items needed for a full service?
Cheers,
Joel
Post #673175 12th Sep 2023 6:49am
DrRob
We have a site sponsor https://www.advancedfactors.co.uk/ or Duckworths
Both offer discount codes online
https://www.fullfatrr.com/forum/sponsors.php
I use Advanced and currently have their Borg and Beck front kit Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #673176 12th Sep 2023 7:28am
JayGee
OEM are Brembo disks and Jurid pads which are not cheap even from indy suppliers. Also depending on your level of ability changing the front disks and pads can be a nightmare as the retaining pins and bleed nipples easily seize in the alloy calliper body. Piston seizure on the rears is also common so you may need new ones or a recon kit. If you download the workshop manual from the Wiki it will have a service section but if the car is new to you and you want to do everythig;
Oil and oil filter
Air filters
Cabin filter
Fuel filter
Gearbox ( Search 'Brodsy') Diffs and transfer box
Brake Fluid
PS fluid
Assuming you have a 4.4 then other 'service' items are;
Clean the MAP sensor
Oil cooler gaskets and turbo feed oil rings if they are leaking and the previous owner has not done them ( and coolant flush and header tank replace)
Intake 'doughnut' to manifold connectors.
Alternator
AC compressor
Aux belt, pulleys and tensioners. 2012 TDV8 Vogue (L322)
Post #673180 12th Sep 2023 8:39am
DrRob
Bodsy for a gearbox Megaflush, transfer box and diffs
www.updatesbybodsy.co.uk Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #673186 12th Sep 2023 9:59am
joel-h
Brilliant, thanks everyone.
I have already had the discs and calipers off in order to fit new dust shields and didn't encouter any problems. Car was previously owned by a guy on this forum who did everything himself and kept very good records so I am hopeful of not encountering any massive pitfalls.
Post #673684 18th Sep 2023 12:05pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
@jaygee
i see you said coolant flush sounds sensible but the header tank could this not be washed out ? just wondering
thanks will
Post #673690 18th Sep 2023 12:45pm
Mikey
Make friends with your local independent specialist. They'll keep most parts in stock, and advise brands/procedures where possible Thumbs Up
Post #673693 18th Sep 2023 1:04pm
