![]() | Home > Technical (L405) > Sdv8 acceleration issue |
| Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626
Check the turbo actuators move freely. |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2777
Does it have the extra section of wiring harness that fits between the block and the original wiring connector? The harness is supposed to prevent oil migration from the sump along the wires to the turbo electronics. N375 is the code for the service bulletin to fit the short harness.
| DESCAT ANDRE Member Since: 18 Sep 2023 Location: Bordeaux Posts: 8
Thank you very much for this response. This actuator problem is known on this forum. I called the garage. The workshop manager told me that to check if the actuator is moving correctly, you have to take out the turbo. Do you think he's right? |
Hello and thank you for your message. I have seen posts on this forum for wiring problems and oil leaking on the electronics. This is not easy to translate into French. I will ask for the fault code and I will give it to you (it seems to me that the garage told me that the fault code is turbo solenoid) They put smoke in the intake and there is no leak. Today they sent the file to land rover Europe service for complicated faults, so we are waiting for a response. The car is in a Land Rover dealership. Thanks again and I hope to give you some information soon. Sincerely, Andrew |
The default code is P004D-77
Good evening, I made a mistake in my first message last year, and for the same fault code, the Land Rover garage changed the LH turbo (i.e. driver's side for the French) |
| Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1442
Check these out
Last year, before we changed the LH turbo :codes were:
Thank you +++ |
Good morning,
| All times are GMT |
