![]() | Home > Maintenance & Mods (L405) > Front lower front control arm bush L405 |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
The part circled should be able to be moved by twisting, but no 'free' movement - and should bounce back if a pry bar is used to deflect it (needs wheel off the ground to check properly).
| knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782
That particular bush has quite a bit of movement and is easily flexed by hand by grabbing the arm and pushing back and forth.
| Seatown Member Since: 30 Oct 2020 Location: Mountains, seaside Posts: 90
Thanks for the replies chaps. On that basis I think the front arm bushes are perfectly normal then!
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
FYI there is a revised ARB bush from JLR available... Has a return surface on the revised bush |
Thanks Craig - what do you mean by a return surface please?
