![]() | Home > Off Topic > laptop fan |
my laptop fan keeps on going all the time, it used to start and stop but now keeps on going basically from boot up..i've taken the back cover off and made sure theres no fluff blocking the vents...any ideas ? |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Sit in the fridge whilst using?...
thanks, do you think if i re-install the OS this might solve the problem @rich.. ![]() |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3926 ![]() ![]() ![]() |
Before doing anything complex, what I did was blast the airways through with a compressor, they were blocked with dust and fluff after that no problem. Geoff |
algt2 Member Since: 01 Jan 2011 Location: Edinburgh Posts: 65 ![]() ![]() ![]() |
If the system is running slow and the HDD activity is pretty full on then a fresh install could help, its maybe worth a try, did a fresh Install on the wife’s laptop after cleaning inside with compressed air and applying new heatsink paste, made a huge difference to the time that the fan ran for but it only lasted a month or so ![]() |
as time goes by i tend to load and un-load software to try out so hence my suggestion of a OS re-install, my registry must full of rubbish doing nothing...
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
If it goes full bore from the moment you turn on IE as the BIOS post's boot it will not be the OS and is unlikely to be anyway.
you might have hit the nail on the head tbone, my battery doesnt hold charge and i brought a higher mAh off ebay which would not charge or read its voltage properly , sent it back and started using my dodgy one again..i'll try your suggestion of not having battery in and see if that solves it.. |
What model is the laptop ? Far to many gone... |
its an acer 5920.. |
I think they all have a problem overheating....
mine has served me very well for the last five years or so, but everything wears out i suppose... |
update, taken battery off and the fan still runs all the time.....need to do an OS re-install now.. |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
Or buy a MacBook Pro. I never hear the fan at all...ever....
