Home > Technical (L322) > Battery drain
JoshVogue94
Wales 2011 Range Rover Vogue 4.4 V8 Santorini Black
Battery drain
Evening all, just over a week since my car broke down and I had to replace the battery I'm already getting the low battery please start engine on the dash. Is there anything common that can be the cause of battery drain to check before I start randomly pulling fuses?
Post #673845 19th Sep 2023 6:15pm
JayGee
How long are you leaving the ignition on without the engine running before the fault comes up? 2012 TDV8 Vogue (L322)
Post #673847 19th Sep 2023 6:18pm
JoshVogue94
Its as soon as I get in the car the message is there
Post #673848 19th Sep 2023 6:24pm
JoshVogue94
Hi Guys bumping this thread, just been sat in the house on my phone and realised no sound was coming from my phone and it was showing that it was connected to a Bluetooth device. When I checked it was connected to the invery in the car. Went out to check the car and it's locked but the radio was lit up showing the range rover logo and the orange blinking power light. Opened the car and locked it again and it all shut down. Has anyone else had this issue? Thinking this is what could be draining the battery if the radio is randomly staying on.
Post #674144 24th Sep 2023 5:20pm
JayGee
I have the Invery BT audio adapter but it shuts down when the car is off but this will certainly be a battery drain if it's not shutting down. BTW my phone connects to the LR bluetooth handsfree and only audio goes through the Invery. 2012 TDV8 Vogue (L322)
Post #674153 24th Sep 2023 7:36pm
garyRR
Faulty diode in your alternator? It's quite common on the 4.4 TDV8 as a cause of battery drain and spurious errors. 2015 Range Rover Autobiography 4.4 SDV8
Post #674168 24th Sep 2023 9:42pm
JoshVogue94
Is there anyway to test this or is it just a case of replacing the alternator?
Post #674169 24th Sep 2023 9:51pm
garyRR
I'll have to pass on that one.
Aside from looking at voltage when the engine is running (13.5V-14.5V), I don't know anything more advanced to check a faulty diode (others may).
I just know a faulty diode in the alternator is a common cause of discharging and strange electrical errors on the 4.4 TDV8 (mine has been replaced also). 2015 Range Rover Autobiography 4.4 SDV8
Post #674170 24th Sep 2023 10:02pm
JayGee
Easier just to replace the whole alternator as the difficulty involved in removing the fan and shroud etc to get to it mean you may as well. As you have a BT adapter that is not shutting down then this would suggest the first thing to investigate - simply unplug it for the time being. 2012 TDV8 Vogue (L322)
Post #674179 25th Sep 2023 7:58am
Super Sloth
These cars can behave strangely with anything but a perfect battery. Budget to renew every 3-5 years.
I use Bosch when I can.
Post #674716 1st Oct 2023 8:26pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Could be barking up the wrong tree here, and I'm sure people who know can confirm/deny this. When you replaced the battery, did you tell the RR it had a new one? I used the IID tool.
Also the Negative lead has a box on it that feeds back charge/condition etc. I forget the name. I replaced this as my 5.0 was being silly after a new battery and giving the warning.
EDIT: Genius of this Parish Caesium posted this, which was the genesis of me changing the cable:
https://www.fullfatrr.com/forum/topic61536.html?
Since I swapped that out it's behaved much better.... Just the knackered Air Con, occasional clunk from the gear selector on braking and inconsistent Audio system... All will be sorted soon I hope!
Good luck!
Stephen Formerly happymadison1978
Post #674729 1st Oct 2023 11:37pm
JayGee
Good point on resetting the BMS via the GAP tool. Thumbs Up 2012 TDV8 Vogue (L322)
Post #674736 2nd Oct 2023 9:49am
