Home > Maintenance & Mods (L405) > which oil
V8Russ
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
which oil
My service light is showing to change the oil now although it was only done 600 miles ago. Should I change it again and what brand/spec. Can I use a standard Castrol 5W-30 oil or is it more specific than that?
Can the service light be reset without a OB2 reader?
Post #674636 1st Oct 2023 11:51am
Phoenix
With a DPF it needs to be C1 specification - I used Millers Oils Trident Professional C1 5w-30 Fully Synthetic Engine Oil as Castrol wasn't available at the time in the correct spec. You don't need to reset via the OBD port, have a look in the WSM (link in the Wiki) for details of how to read & reset the oil level & service interval reset
Post #674637 1st Oct 2023 12:18pm
caymanblack
Myself and I think Kot use this.
https://www.opieoils.co.uk/p-218910-petron...1gQAvD_BwE overfinch modified
Post #674640 1st Oct 2023 12:27pm
Kot
Yep C1 it is, and PETRONAS is good enough for Lewis Hamilton and co. Rolling with laughter
Opie oils were doing 20% off
600 miles is crazy though, who did the service reset?
being paranoid on fuel dilution I personally would change the oil so you know its done, do a search and get the sealy vacuum pump.
Service reset  2018 SE SDV8 4.4 Byron Blue
Post #674645 1st Oct 2023 1:48pm
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
600 miles and needs another oil change. Thats mad even by ffrr standards. I’d be doing mine once every two or three weeks at that rate Shocked Shocked 2016 4.4 diesel
Post #674663 1st Oct 2023 4:12pm
supershuttle
Mixing oil
I don't mean to hi jack the thread but I have some some oil left over from changes I have done (I always get 10L but my Range Rover takes less), some Smith and Allan some Castrol and I was thinking of the offer from Opie for next time(Petronas).Can it be safely mixed if it's all C1 5-30W and fully synthetic. Or should I stop hoarding and take it to the tip, Geoff
Post #674670 1st Oct 2023 5:10pm
Phoenix
It depends how long it takes the OP to do 600 miles...
Post #674689 1st Oct 2023 7:14pm
Phoenix
Re: Mixing oil
If it's all the same viscosity, specification & composition, then it'll be fine.
Post #674691 1st Oct 2023 7:15pm
Tdtj
I think judging by the reaction of the op seems surprised also 2016 4.4 diesel
Post #674702 1st Oct 2023 7:54pm
V8Russ
I did 700 miles in under 4 weeks of driving.
Its strange I was hammering it a bit to see if it made any difference, and it did, the mileage service interval went up. Soon as i hit motorway speeds for an 1/2 hr to an 1hr it reduces.
Anyway I did my first RR oil change today. Very easy with the vacuum pump.
Costs were, oil £120, filter £8. torque wrench £40, 36mm socket £16.
Post #674705 1st Oct 2023 8:00pm
Phoenix
Then there is a concern, either the oil level is not reading correctly, there is a sensor issue with the DPF regen or the last oil change was not reset correctly. Use this oil change as a baseline and monitor the service interval countdown. would also be helpful to do a full vehicle DTC read, if you have the capability.
Post #674707 1st Oct 2023 8:19pm
V8Russ
DTC?
Post #674708 1st Oct 2023 8:21pm
Phoenix
Diagnostic Trouble Code - 'fault code'.
Post #674709 1st Oct 2023 8:22pm
V8Russ
Reset saying 16030 miles until service, so will keep an eye on it.
Post #674712 1st Oct 2023 8:22pm
V8Russ
Ill need to buy a code reader but I believe they're around £500-600.
Post #674713 1st Oct 2023 8:23pm
