![]() | Home > Technical (L405) > Plugging in Mongoose JLR gives instant error codes |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 419 ![]() ![]() ![]() |
You need to remove pin 13 from the mongoose connector as it is not implemented on earlier vehicles but 2013 on it causes a short on the MS Can and hence you get lots of warning lights and errors until you unplug it and leave the car to shutdown.
FleXzoR Member Since: 28 Jan 2013 Location: Bruges Posts: 44 ![]() ![]() ![]() |
Thank you for your prompt reply!
Works like a charm! Thank you! MY2008 Buckingham Blue Supercharged - gone
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1531 ![]() ![]() |
I wish I’d known this … I’d spent ages trying to get it working and had the above issue … I’ll maybe try again. V8 or else ... |
And me, my solution was to buy the genuine JLR VCI, then I discovered the pin 13 solution, worked perfectly, but just use the JLR unit now as most Mongooses are clones and *can* screw up when flashing ecu's.
