![]() | Home > Maintenance & Mods (L322) > suspension issue |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 531 ![]() ![]() ![]() |
Right managed to get car to raise and lower still getting the error can’t calibrate the suspension and now in the 4x4 screen all of the wheels have the red tags flashing under the wheels |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35679 ![]() ![]() |
pretty sure you can reset to original settings [before you played with them] ... - .- -.
Is that in the height adjust menu .? |
tried to reset to default it starts to update but then fails on get error e 0 |
ok have tried hard reset ...........still the same fault .i have been through all of the rlm calibration setting you name it i have tried them all nothing as soon as i try to raise or lower the suspension get bong and suspension fault .im at a loss |
What is the 4x4i screen showing? all wheels at the same height? any flashing red cursors? What DTC is set after attempting calibration?
right screen shows all bottom marker’s flashing red , if i try to raise car i get error and says standered height (but it’s. it moved) if i lower car error and then shows access height ……it does try to raise and lower but then just stops and errors….whats so frustrating it that it was all working fine up to the point i went to calibrate suspension…..wife not happy with me |
Let's take a step back - why did you decide/need to recalibrate the suspension height?
i was thinking of maybe disconnecting the air suspension control module (if i can find it ) and see what error codes pop up ???? |
i have replaced one of the rear airbags and one of the front height sensors ,and when i measured each corner the other week they where all different but couldn't do anything about it till now as i didn't have a gap tool |
The rear airbag shouldn't have made a difference as it's the height sensors that measure the height, the airflow to & from the airbag is as a result of the measurement, not the other way around.
ok understand ref the air bag |
They may be too far out to allow a successful calibration - you might need to adjust some values so they're all a bit closer together to get a calibration file to build (Autologic & IDS can do it 'as factory')
phoenix....appreciate the help. those heights you have said ring a bell and im sure my measurement's where between 30-40 mm different just going to search for "(from GAP IIRC) telling you how to manipulate the measurements" |
