Home > Technical (L322) > Aftermarket LED tail lights
Fullfatfan
2012 Range Rover Westminster TDV8 Orkney Grey
Hi all, it looks like I have a near side brake light out and being as they sealed units they cannot be fixed without a new complete unit ??
Has anyone actually managed a “fix” ?? Failing that are the aftermarket replacements any good?
Are they simply straight swaps or has anyone had issues??
2012 Westminster
Thanks in advance
Post #674913 4th Oct 2023 9:25pm
DrRob
Are both number plate lights working? If the fuse blows it takes out a whole sidelight with it and the number plate lights Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #674915 4th Oct 2023 9:42pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
I got a replacement rear light that is a look alike, it works perfect only difference is that it has the illuminated side lens that is normally just a reflector. I think this is a USA market feature.
It was a third of the price of a genuine part. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #674919 4th Oct 2023 10:43pm
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
It's a North American option - it may be possible to remove the bulb/disconnect that part of the unit.
Post #674930 5th Oct 2023 11:41am
Fullfatfan
Yes all light work ok other than brake light, funnily enough I swapped the units over from one side to another last week just to check wiring loom on the brake light out side and it worked , swapped back to original sides ant brake light worked again ???
Only other thing I’ve done is fitted LED bulbs in reversing light as other are crap, wonder if they affected anything?? I will put original bulbs back and see
Post #674964 5th Oct 2023 9:36pm
Fullfatfan
Did it work straight out of the box????
Read that quiet a few have problems and need a wiring modification to work properly
Post #674965 5th Oct 2023 9:38pm
V8 Bob
Yes worked straight away with no need for any programming it cost £103 in June 2021… just checked and can’t get one from same supplier now 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #674969 5th Oct 2023 11:32pm
V8 Bob
I’ve just ordered a near side rear light to match the offside with side marker so should have a fully working original 2012 light available if anyone is interested 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #675113 8th Oct 2023 8:38pm
DrRob
Got a link? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #675446 12th Oct 2023 8:17pm
