(sold) 2011 Range rover Vogue TDV8 (overland prepped) | |
I have for sale my 2011 Range Rover Vogue TDV8 which has some mild overland prep and extensive maintenance record (over £5200 spend in the last year)
2011 Vogue 4.4 TDV8
Full Vogue spec with split screen TV
Ivory leather interior
142k miles (11k a year)
Full-service history
Removable tow bar
1 year’s MOT
No rust but body does have some age related marks as you would expect.
Price £10.5k with the camping equipment and £10k without (I appreciated there are cheaper cars out there but how many of them have this maintenance record?!)
Over the time I have had the car I have covered over 13k miles it was to be a keeper so i maintained it at great expense using a well-respected Land rover specialist. In total in the last year, I have spent around £5300 in maintenance and another £1800 in upgrades (see details below)
I have been using the car for work but also some off-road camping/ overlanding and have fitted a leisure battery for fridge and build a set off pull out draws in the back as well as sleeping platform. I also fitted 4 brand new duratrax tyres at a cost of £800 with a matching tyre and alloy wheel for the spare (£200). Final thing I have done to enhance the car is a back box delete which is very subtle but gives the car that nice V8 rumble it should have from factory.
The car can be sold either with or without the camping/ overlanding equipment. The car has been incredible to own and we have had some amazing adventures in it but sadly a change of circumstances mean that I need to move it on. Many more photos/ receipts etc can be sent via what’s app/ messenger etc. Please ask if you have any questions.
previous owner maintenance
2021/ 2022 New Air Compressor
2021/2022 Replacement Front Shocks and Airsprings (Both Sides)
2021/2022 New Upper Front Suspension Arms (Both Sides]
2021/2022 New Lower Front Suspension Arms (Both Sides)
2021/2022 New Front Lower Ball Joints (Both Sides)
2021/2022 New Front Discs and Pads
2021/2022 New Rear Discs and Pads
2021/2022 New Rear Handbrake Shoes
2021/2022 New Rear Brake Callipers (Both Sides)
2021/2022 Turbo To Oil Cooler Oil Feeder Pipe ‘O’ Rings
2021/2022 New Air Intake Manifold Hoses (Silicon)
2021/2022 New Top Coolant Hose Assembly
2021/2022 New Windscreen
2021/2022 Oil Change with Oil Filter
2021/2022 Air Filters (Both)
2021/2022 Pollen Filter
2021/2022 Fuel Filter
2021/2022 Gearbox Flush and Transmission Fluid Change
2021/2022 Transfer Box Fluid Change
2021/2022 Front and Rear Differential Oil Change
2021/2022 Brake Fluid Change
Maintenance I have done on the car.
14/10/2022 tyres and alignment wrangler durtrax £813
28/10/2022 radiator, coolant and aircon, V belts, oil change £1,245.70
01/11/2022 transmission and powertrain module updates £90
23/12/2022 coolant £32
23/12/2022 tool for fan £50
23/12/2022 alternator £249
23/12/2022 airfilters Mann £40
19/02/2023 locking wheel nut tool £17.64
24/03/2023 Battery £132.74
24/03/2023 20 wheel nuts £80.00
04/04 2023 oil service, pollen filter change, rear windscreen wiper £96
04/04 2023 fuel filter change £48
04/04 2023 power steering fluid change £38
04/05/2023 rear rose joints changed plus alignment? £395
10/05/2023 boot gas strut plus door seal £158
12/06/2023 tailgate struts/ cables £43
Jun-23 brake lines both sides renewed fron to back £332
21/07/2023 rosh bush lower, rear shocks, front lower arms, exhaust put on (welded etc) £1,468
24/08/2023 final stage resister £56
04/09/2023 blower motor £68
20/09/2023 MOT £35
Upgrades etc
19/06/2023 roof rack 159
11/11/2022 LED reversing lights £45
05/12/2022 Osram night breakers £99
10/10/2022 new rear plate £12
19/06/2023 exhaust 279
10/10/2023 Gap tool £438
19/06/2023 leisure battery £132
19/06/2023 split charge system £69
19/06/2023 draws materials etc £300
19/06/2023 fridge £215
08/10/2023 boot liner £30
08/10/2023 dog guard clips £30
08/10/2023 start stop button £17
08/10/2023 genuine rubber mats £69
08/10/2023 dog guard net £67
08/10/2023 hatch bag boot liner £30
