Home > Technical (L405) > Tailgate drops down after opening?
ewings
On the new to me L405 my wife was questioning the height of the tailgate as opens and then drops down?
She’s tried to follow the manual to increase the height but to no avail,
Video to show:
https://share.icloud.com/photos/052RgiawHze3FCjaCSntNdVRA
Is this normal or is there a problem?
Post #675251 10th Oct 2023 5:21pm
Phoenix
It could be an issue with one of the motors, hinges or anti-trap sensors if the reset procedure isn't working. It sounds to me that excess current is being drawn at the top extent causing the control module to go into 'topped out, back off' mode and lower the tailgate slightly. Not an easy one to properly diagnose without access to live values - does the liftgate feel consistent in its movement if you manually lift & lower it? Does the alarm siren chirp when the liftgate lowers itself?
Post #675252 10th Oct 2023 5:29pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Try this video from PowerfulUk
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #675253 10th Oct 2023 5:29pm
