![]() | Home > Maintenance & Mods (L405) > Front End knock / rattle almost constantly |
Undertray?
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 258 ![]() ![]() ![]() |
No visible under tray hanging off and I inspected the knuckles which look ok (thankfully!)
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
The block is on the passenger side, so it could be. Kev
It could also be one of the pipework support bobbins has come away from it's fixing, allowing one of the pipes to rattle on the subframe or body. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8738 ![]() ![]() ![]() |
They look like this, they should have another threaded part on the bottom... They "look" OK and in one piece till you move them..!!
They're the ones - changed three on mine... |
Super useful stuff guys thank you. I noted a post about the pipe work rattling, will definitely look at this.
Here's the parts catalogue pictures, the insulators are at location 2C239 in both images
Thanks for that. I will definitely look at these.
Update on this, I have been busy with things and not needed the car, so I have not organised any review or parts yet.
JAD Member Since: 19 Oct 2020 Location: Wirral Posts: 34 ![]() ![]() ![]() |
Could be the upper ball joint which is bizarrely on the bottom of the hub. Have had to do the same passenger side twice on mine within about 5000 miles. Gives a dull knocking sound on uneven surface but really hard to find any movement in it while still on the car! |
That’s useful info thank you. Seems to be the way with these, hard to find play when 2.5t is pushed down on them |
Update on this. Odd one, hopefully useful to anyone chasing this,
