Home > In Car Electronics (L405) > SATNAV Question
Matt Buckland
United Kingdom 2017 Range Rover Autobiography TDV6 Santorini Black
SATNAV Question
Hello All,
2017 L405 AB:
Odd behaviour from onboard SATNAV yesterday - The system booted up, accepted search, but refused to update position of car as I was driving. I drove about 20 miles and screen still showed original starting position.
I performed a couple of brief ignition cycles - and got the same result.
I then parked up for about 15 minutes and on return to the car, everything was fine, as if I'd imagined the whole thing Very Happy
Any ideas what might have caused this? Car is still under warranty, so if the SATNAV aerial, or other module is on the way out, I'm keen to get the local stealer to investigate whilst I'm still covered.
Thanks in advance L460 460e PHEV AB. Belgravia green.
Previous toys:
L405 2017 TDV6 AB
4.4 TDV8 Westminster. Santorini Black
1976 Lightweight
4.0l P38
2 Disco 3s
Jaguar XJ6 (X350)
Jaguar XJ8 (X308)
Jaguar XK
Jaguar XK8. Confirmed JLR nut.
Post #675942 20th Oct 2023 8:30am
Phoenix
Likely just a voltage spike, even with no GPS signal, the position should update using the composite speed signal & steering angle signal and 'snap' to the nearest road, get it checked out (and if it occurs again, get your passenger to video the concern) - even if they say 'unable to reproduce concern, no fault found' it will have been reported in warranty so should be resolved 'as if in warranty' if the concern becomes permanent later, this is often the case with sporadic faults that can't be replicated at time of test.
Post #675946 20th Oct 2023 9:37am
Matt Buckland
Hi Phoenix,
Oh great tip to video the problem if it occurs again, saves the endless “can’t replicate” argument!
Thanks for that. L460 460e PHEV AB. Belgravia green.
Previous toys:
L405 2017 TDV6 AB
1976 Lightweight
4.0l P38
2 Disco 3s
Jaguar XJ6 (X350)
Jaguar XJ8 (X308)
Jaguar XK
Post #675950 20th Oct 2023 9:51am
