Home > Maintenance & Mods (L322) > Anyone used a coolant vacuum pump?
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Following yet another coolant hose failure (due to fan damage) I will be replacing all the coolant.
I like the look of the vacuum pumps to refill, but has anyone used one?
I understand the way it works, but I don't want to "over vacuum" and break seals etc, so may need to vacuum twice. How does that work? My simple mind says that if I vacuum with some coolant in the system, it will just suck that out rather than create a vacuum?
Or I am being thick, again?
Post #676035 21st Oct 2023 11:04am
Phoenix
I use one most weeks - never had a problem although too deep a vacuum can apparently cause water pump shaft seals to invert.
Vacuum is vacuum, regardless of the space you're evacuating with it, we use it on fully & partially drained systems, it's rare to draw any coolant out, when it does come out, it's only a mist.
Vacuum to the red line on the gauge, it'll be fine - the benefit is that you don't have to go through a convoluted bleed process (unless it's mostly filled and there is no clear path to vacuum the higher parts of the system), it's also a good reason to drop as much coolant out as you can and refill with fresh. Modern organic coolants do have a finite life.
Post #676046 21st Oct 2023 2:14pm
philip1972
Perfect, thank you.
I have just ordered one Thumbs Up
Post #676048 21st Oct 2023 3:17pm
