![]() | Home > General > Wading an L322 |
It's not low down, it's approximately the same height as the glove box. The L322's were used on the same LRE tracks with no adverse effects, if the water is deep enough to get drawn into the FBH, you're in too deep and will have bigger problems... |
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 107 ![]() ![]() ![]() |
Ah that makes sense, I thought it was lower down for some reason, I did wonder if they had issues with them around the courses but obviously not. |
The exhaust & silencer is lower down, the thing about wading is to keep moving - but not overtake the bow wave, you'll be surprised at how low the 'tide mark' is on the side of the vehicle compared to the front. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8055 ![]() ![]() ![]() |
They should tell you on the LRE - slow in, accelerate slightly to create a bow wave & then steady, to maintain it.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Why risk it? Probably not an issue for the FBH but flooding the box sections etc will not help prolong it's life from rust, ditto brake lines etc. The possibilities of dragging water into places it shouldn't be is simply not worth the risk in your pride and joy. I would just pay to go on a day in someone else's vehicle, then it doesn't matter ![]() 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Alternatively it helps wash crap out from them. Different vehicle but my 1994 Defender on its original chassis has been pressure washed a dozen times in my ownership (last 15 years), waxoyled once, and had bits of paint touched up intermittently.
Glad it works for you. L322 seems to suffer a lot in the area of brake pipes, rear wheel arch, and in my case subframes. Mine was regularly pressure washed underneath but the amount of rust was alarming compared to my previous car (VW Touareg). BMW i3 Electric Car
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
Speaking from experience they wade pretty well, when I drowned fatty off roader in a Welsh river the water was just over the BECM under the passenger seat.... It conked out when water got to the MAF, took it off, blew it out and it started, lots of faults and spurious things switching on and off but it did get us 200+ miles home...
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3239 ![]() ![]() ![]() |
think this holds the record thus far!!
