![]() | Home > Maintenance & Mods (L322) > AC Pressures-Low side OK but high side low-cause? |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
Could be low on refrigerant, the wrong refrigerant/oil quantities added, incorrect refrigerant specification (some of the 'top up' bottles aren't actually the right refrigerant). Or mechanically it's likely to be worn seals in the compressor preventing full pressure being reached or pressure blowing by the seals. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
You can only rely on pressure readings once the refrigerant charge weight is known to be correct, there needs to be enough refrigerant to allow a change of state from gas to liquid once compressed. Before recovery, I'd suggest a leak test with a decent sniffer and a visual check for corrosion, stone damage or (compressor) oil staining around the flexible hoses, condenser and charge points. If all OK, then recover, VAC, test under VAC then pressure, if OK, then recharge with the addition of 5-10ml of UV compressor oil, running the system for a good 30 mins to distribute the oil. Monitor with a UV torch after a week or so. |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 154 ![]() ![]() ![]() |
How did you arrive at the 50psi pressure? That is way too high in a compressor running situation and very low in a static situation unless you are in the arctic. If we assume that is your static pressure so you are low on refrigerant.
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
I used some gauges in a kit (only cheap ones but only wanted to get an idea)
Post edited as I uploaded the wrong chart! |
If you a running in a fairly high ambient of 29C then the pressures are liable to vary depending if you are testing first thing in the morning to testing last thing in the afternoon as the temperature of the system under the bonnet especially if the car is outside is unlikely to be 29C.
I will take it to an engineer. I have finally found someone who seems to understand AC so in the next few weeks I will go and see him. (I am still waiting for delivery of some coolant hoses etc so cant go anywhere until then).
